Results 1 to 5 of 5
Thread: 10.17@134.93 ~N/A 347 c.i.d.~
    Cylinder Heads: AFR 205cc (Milled to 55cc Chambers)
    Vacuum Pump: Moroso 3 vane (14-15 inches of vacuum)
    Rockers: Comp cams - Pro Magnum with Stud-girdle
    Block: 302 Sportsman (B50)
    Main Support: Canton
    Windage tray: Canton
    Crank: Scat 4340 3.400" stroke
    Rods: Scat 4340 H-Beam 5.400"
    Pistons: Probe 4.030" 9cc Dome - 14:1 C/R
    Bearings: Federal Mogul race
    Camshaft: Straightline Performance Custom over .690" lift and more than 260 deg duration @.050
    Intake: Edelbrock Super Victor - 1262 port match and plenum blend
    Carb: Pro-systems TBD cfm
    Headers: Kooks - Stepped (1 3/4 to 1 7/8) 3" collectors (Modified by US to make them actually fit)
    Exhaust: 3" Bullets with turndowns
    Transmission: 5-speed Face plated TKO600
    Clutch: SPEC Stage III
    Axle: Moser Spool with 4.88:1 gears
    Rear Tires: Mickey Thompson 28 x 10.5 ET Drags
    Rear Wheels: Weld Pro-Stars 15 x 10 with 6.5 Back-spacing
    60ft = 1.33
    330ft = 4.19
    1/8 ET = 6.50
    1/8 MPH = 106.3
    1/4 ET = 10.17
    1/4 MPH = 134.93
    3,000 lbs. with driver
    978
    Thats gettin' it right there!
    In the neighborhood of 590 FWHP & 485 RWHP. 1.69-1.7 FWHP per c.i.d.
    7,700+ through the lights.
    Petersburg,PA. 16669
    816
    any vids?
    88 GT...and some boost
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    heres a very similar motor that is for sale on another site http://www.nmradigital.com/forums/sh...ad.php?t=72725
  1. 347 Stroker
    Last Post: 10-25-2011, 10:05 PM
  2. 347
    Last Post: 12-14-2010, 02:55 PM
  3. 92 347 Lx
    By Pedd92LX in forum Ford Vehicles
    Last Post: 09-10-2009, 08:52 AM
  4. 89 Lx 347
    Last Post: 04-04-2009, 09:21 PM
  5. 347
    By Inkdcountryboy in forum Fox-SN95
    Last Post: 04-05-2007, 04:49 PM
