Results 1 to 5 of 5
Thread: Special Tool?
    Member RUSH2112's Avatar
    Hopewell, PA
    754
    Special Tool?
    Is there a special tool to safely and easily remove the center caps on the 5 star pony wheels? My stock aluminum wheels are kinda chewed up cause I just use a flat head screwdriver, but I need to find something for my chrome pony wheels.
    What does everyone use, or what would a Ford Tech use? Any part number or information would be appreciated. Thank you.
    North Hills
    1,229
    screwdriver with a cloth wrapped around the end?
    Yep - but be real careful - the finish on the chrome centers won't hold up as well as the regular centers. Maybe the rounded end of a bottle opener with a cloth around it - or something like that.
    I cant remeber what vehicle this was for, was thinking my T-bird, but could be wrong.......
    Anyway, what came with the car was a normal looking lug wrench (duh), but on the handle was a few inch long piece of metal with a little hook on the end. Basically, you put the tab under the cover, and the tire iron against the tire, and pulled OUT. This kept everything from touching the wheel, and all of the force was out, nothing against the wheel. Same type of caps as ponies.
    I have a similar issue with my waffle stars, they are powder coated, and getting the covers off is a PITA. Those suckers have a wire spring behind them.
    I just wish I could remember what car that set-up came with, might be imagining the whole thing ;)
    Senior Member 85stang's Avatar
    Sep 2007
    irwin
    227
    Thumbs up
    my explorer has a tire wrenchthat has a flat head hook at the end that is rubber coated.grab one from a junk yard, it works pretty good.
    85 mustang gt
    01 mustang
    06 F150
    65 t-bird (project)
    will:loco:
  1. FS: Matco muscle car tool box/ tool car
    By slimvdub in forum For Sale
    Last Post: 06-09-2013, 07:30 PM
  2. need some tool help
    By J-rod in forum The Bar
    Last Post: 04-27-2007, 09:57 PM
