when changing from a c4 in a stang to an aod, what all needs to be changed? the flywheel and converter are differeant, right? will the tranny lines work off the c4 or not?
Pretty much everything is different. I have a nice set of factory aod lines if you need some.
The Oil Dipstick tube will be about the only thing that will be reused.
