Can you buy tubular a arms with spring perches or are they for coil overs only?
Thanks.
Thanks.
05 F150 STX - work
03 Focus SVT - daily
00 GT - 453rwhp for the weekend
"If you want something done right, do it yourself"
2013 Mustang GT
1999 Contour SVT
Depending on where you get them, you can buy them with or without spring perches. I run a PA racing tubular K member and the A arms can be ordered with or without spring perches.
AJE has arms with spring perches.
I have a used set of 94 - 04 AJE A Arms with spring cup for sale for 225.00. They only have a few thousand miles on them but the powdercoating is flaking off.
would they fit a qa1 k member?
05 F150 STX - work
here's the problem... the reason I don't want to use my stock a arms is because with the qa1 k member, my 17x8 04 cobras stick out of the wheel well about an inch. Looks really dumb. I was hoping that the tubular arms helps put the wheels back in. Any input from anyone?
05 F150 STX - work
Some guys run Fox arms, they will tuck them in aprox 3/4 - 1 inch.;)
do the fox arms just bolt up with no problems? are the fox arms just smaller than the 99-04 arms?
05 F150 STX - work
You will need to either run a ball joint spacer or Steeda X2 ball joints, install steering travel limiters to keep your wheels from rubing at full lock, and probably have to cut some of the threads off where the outer tierod screws on to. Other than that they go right on.
can i still use my front sway bar with the fox arms? i heard of fitting problems?
any grinding with the fox arms to fit a tubular k member?
05 F150 STX - work
Does anyone know anyone who has front springs laying around? I put my fox arms on and I ended up cutting my springs just a bit too much.
05 F150 STX - work
Mater has some 03 cobra fronts for sale on ebay.
