Results 1 to 13 of 13
Thread: Gear choices>>>>>>
    Senior Member LXguy88's Avatar
    Ohio/Blairsville, pa
    127
    Gear choices>>>>>>
    Thinking of gears for the 04. Its a 5 speed. I'm considering 3.90's because I do alot of highway driving and I believe 4.10's are to high and that 3.73's are to low. Any thoughts? thanks
    EVOL302GT
    1990 LX -SOLD- now SVTGT's car
    1987 GT >cobra inspired
    1984 Chevy Silverado shortbed- 305 monster
    5,822
    sounds like you got it all figured out.
    EDIT: I had 4.10 in my PI-swapped '97 and I got 3.73 in this '01. Your assumptions are correct, IMO.
    3.90 seems like the best gear for the 4.6, but Ford doesn't make that gear. So, it's a little bit more work to install a 3.90. Most mechanics will charge you more to put a Motive or Richmond gear in than a Ford gear. Maybe they can elaborate.
    2019 Colorado ZR2
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    Stay FRPP and go 4.10's.
    i say 3.73s if you do ALOT of highway driving but if its only a couple times i say 4.10s
    or if your a real man go 4.33s hahah JK
    5,822
    4.10's don't give you much room for improvement in the 1/4 unless you want to shift to 5th. 4th tops out about 108mph.
    I don't know about 3,90s, but these 3.73 will do about 125 just over 6K rpms in 4th. If you like to "air" it out every once in a while without shifting into that 747 overdrive, do the 3.73.
    I got 23.9MPG coming back from Carlisle today with the 3.73.
    2019 Colorado ZR2
    Melcroft
    4,178
    Wow, that kind of sucks. My mach with the 4.10's was good to about 122-125 before topping out 4th. That was just about perfect.
    127
    My brother runs motives with no problems. The fox has ford gears but the damn thing is not running yet. 4.10's just seem to high. 3.73 just seem to low for a SOHC engine. RPM's and all. I'll be doing the gears just like my fox.
    EVOL302GT
    5,822
    6,800 redline? If you removed the rev-limiter on the 2v, you might be able to get 110-112? at 6,200. there are calculators somewhere on the innanet, but I'm too lazy to look right now.
    2019 Colorado ZR2
    Let me clear up the murky water here.
    With 4.10's in 4th (1:1) with a tire that is 26" tall 117 MPH can be achieved with an rpm of 6,199 rpm.;)
    5,822
    EDIT: from my own personal experience and maybe the tach or speedo was off? At just over 6,000RPM in 4th the speedo was 108-110mph.
    2019 Colorado ZR2
    One I use @ the track. Here's another one that close as well from the corral.
    http://www.corral.net/tech/
    127
    top speed. I don't think we're all on the same page. I want a top speed of over 120 but am not doing 3k at 80.
    EVOL302GT
    Melcroft
    4,178
    That was about my top of forth, so it would be about 6800-6900 rpm's. I believe fuel cut out was 7000.
  1. Brake caliper choices
    By sinful rides in forum Fox-SN95
    Last Post: 07-04-2012, 12:34 PM
  2. Transmission choices (long)
    Last Post: 10-24-2011, 10:08 PM
  3. Rim Choices.....
    Last Post: 07-06-2008, 08:58 PM
  4. wheel choices
    By 89stang in forum The Bar
    Last Post: 07-04-2008, 12:40 AM
  5. Heads//Cam Choices?
    Last Post: 04-30-2008, 11:10 PM
