Results 1 to 5 of 5
Thread: About to install long tubes any suggestions
    Lovin my 302
    Chicora, Pa
    116
    I Just got a set of BBK long tube headers and an off road X pipe. I have the Lakewood blow proof bell housing any Ideas that might make things easier. Thank you
    buy a swear jar.
    North Hills of Pittsburgh
    430
    Take your time and walk away from the project when things aren't going well. I just installed a set of Hooker LT's but I did it while I was installing the new engine.
    2016 GT Premium
    Lots of fun!!!! I did mine as well. 1 3/4 tubes. Motor was out. I took them back out and put them back in with the motor in. You need to un-do the motor mounts and lift it up. I also think the steering shaft has to come off. I cant remember.
    430
    Yeah - I had to jack my engine as well. It helps to jack the engine using a block of wood under the oil pan. Offset the wood/jack to the side of the oil pan so the motor will tilt to the side you are installing. I found it harder to jack the engine straight up - not as much room. Disconnect the bolts holding the tranny mount to the crossmember for additional lift height of the engine.
    2016 GT Premium
  1. long tubes
    Last Post: 04-29-2012, 12:37 AM
  2. best long tubes for an 03 cobra
    By map22 in forum SN95-New Edge
    Last Post: 01-21-2011, 07:22 PM
  3. Fox Long Tubes
    Last Post: 07-20-2008, 03:13 PM
  4. long tubes headers for 03 gt
    By yellowstang03 in forum Ford Parts
    Last Post: 02-24-2008, 07:07 PM
  5. foxbody long tubes
    By Rodeheaver's in forum Ford Parts
    Last Post: 06-07-2007, 05:22 PM
