Results 1 to 9 of 9
Thread: smog pump elimination
    Oct 2007
    Baldwin
    259
    When a person eliminates their smog pump, what do you use to cap off the inlet on the X-pipe? I actually plan on keeping the pump, I just want to eliminate the tube that goies into the x-pipe, as it doesn't fit my new pypes x, and the hoses get in the way of my headers So i'm going to leave the pump on connected to the heads, but not the x-pipe.
    2012 Husqvarna TE 449
    2007 BMW E92 328xi
    2003 F250 Superduty
    2004 SV650
    4,321
    Quote Originally Posted by badf250 View Post
    i cut the tube off, smooth out the trunk on the pipe and weld a small square plate over the hole. i have had cars come in with it cut and the end pinched off!!! i have also seen cars with a short piece of rubber with a bolt in the end!
    out in the woods
    4,948
    cheapest route
    done this a few times
    4,321
    cheapest route
    now that i think about it, there is a pipe at the shop now that isn't going back on the car...anybody want the rubber hose and bolt!!!
    Castle Shannon
    1,276
    they make metal caps for metal tubing. just some flux, silver solder and a torch and you you can sweat in on like doing copper water pipes
    Oct 2007
    Baldwin
    259
    That would work.
    2007 BMW E92 328xi
    2003 F250 Superduty
    2004 SV650
    Oct 2007
    Baldwin
    259
    The solder can take the temp of the x pipe without melting?
    2007 BMW E92 328xi
    2003 F250 Superduty
    2004 SV650
    Castle Shannon
    1,276
    that's why i say silver solder. not the typical lead/tin water pipe stuff. unless you're turning your pipes red with a huge turbo you'll be fine, it has a much higher melting point but also costs a lot more. if the pipes aren't hot enough to cook the rubber hose... i have a roll here but i think i'm out of acetylene.
    Oct 2007
    Baldwin
    259
    I have map gass torch at home, and I have access to a oxy acetelene torch at work. can I buy silver solder at lowes or something? My motor is stock except for the exhaust so It won't get any hotter then the cats, I imagine.
    2007 BMW E92 328xi
    2003 F250 Superduty
    2004 SV650
  1. Smog pump delete?
    By PITT40 in forum Fox-SN95
    Last Post: 06-18-2010, 09:32 AM
  2. smog pump help
    By 94gt5.0 in forum Fox-SN95
    Last Post: 02-22-2010, 04:58 PM
  3. Wanted- 94-95 Smog Pump
    By gmkillr in forum Ford Parts
    Last Post: 02-21-2010, 04:14 PM
  4. smog pump removal?
    Last Post: 07-21-2009, 07:21 PM
  5. fox smog pump
    By PSPstang in forum Ford Parts
    Last Post: 09-26-2006, 04:51 PM
