I hope to stir some intelligent discussion here… I have heard different ‘philosophies’ about cold air intakes. First of all I have seen a beautiful BMW 540 destroy it’s engine because the air intake was down by the air dam. He was in the city after a ball game. It had rained. As he left the ball park parking he went though a puddle (at about Mach 2). It was deeper then he expected and he sucked up some water. It made it into the engine and hydro locked the V8.
No low scoops for me.
So as I see it I have two / 2.5 options.
Pros / Cons
- Use a cold air intake that pulls air from inside the fender well
- Use a cold air intake that pulls air from the engine compartment. The ‘kit’ I have is just a cone filter that attached to the end of the Mass Air Meter.
- Take option two and build a sheet metal box to block off the hot air from the engine compartment and hopefully pull just the colder air though the radiator support and head light area.
Some people say that it better to pull the hot air from the engine compartment then to pull it from inside the fender skirt because the bend in the air flow cause ‘to much air flow disturbance’. Is this baloney? I would think the air flow issue would not out weight the hot air issue.
Your options?
All thing being equal I was sure I wanted a pull the air from the inside of the fender well. Once I got the parts, there was a new wrinkle to the story. The filter for the inside of the fender well is significantly small then the cone filter that goes in the engine compartment.
Okay. I quit. Someone tell me their experiences with both setups.
