Results 1 to 1 of 1
Thread: Fox Body Parts For Sale
    NOS EFI Nitrous Oxide Systems
    Nitrous Oxide System, Big Shot, Wet, 150-300 hp, 10 lb. Bottle, Blue, Ford, Mustang, 5.0L, Kit
    Brand new in box with a FULL bottle. This kit is designed for the stock intake.
    $400.00 Summit advertises this kit for 685.95
    http://store.summitracing.com/partde...5&autoview=sku
    Part Number NOS-02119NOS
    Two 165 R15 Cornell Euro Metric Tires
    *Radial construction
    *Perfect for 15" x 3.5" and 15" x 4" size rims.
    *over 50% tread remaining
    * $25.00 takes the pair.
    2 Good Year Eagle 27.0x4.5x15 Front runners
    Under 10 passes on these tires.
    Summit advertises these front runners for $155.95 per tire.
    $100.00 for both
    *Decrease rolling resistance and add stability when using a bias ply rear tire.*
    __________________
    Two Good Year 28x9x15 full slicks
    Approximately 1/3 life left in them.
    $30.00 for the pair.
    A9L computer
    $125.00--includes shipping.
    Crane Adj. fuel pressure regulator for 86-93 EFI fox
    *used
    *great condition
    $50.00
    1993 HVAC box
    The big black assembly that has the blower motor, heater core, and ducting that resides behind a fox's dash.
    Make an offer.
    25,xxx mile 1993 5.0L left and right engine mounts and trans. mount
    New from Ford:
    *left $46.79
    *right $80.98
    Trans $ 26.76
    $154.53
    Not a single tear in them, and they are out of the car to boot.
    $50.00 shipping included.
    Pro-M 80mm M.A.F. calibrated for 30 lbs. inj.
    Works great! Conical filter included. Going to a speed density set-up, so no longer need.
    $150.00
    K&N replacement filter for 94-95 5L
    New in box. Twenty Bux
    New Centerforce clutch disc
    *Centerforce Performance Clutch Discs
    *Clutch Disc, Organic, 1 1/ 16 in. Diameter Shaft, 10-Spline, 10.4 in. Diameter Disc, Ford/ Mercury
    *Part # CTF-381021
    *Summit=84.95
    $ 40.00 (NEW IN BOX)
    1993 cooling fan/fan-clutch
    EXCELLENT condition. No cracks in fan blades. fan clutch will enage and dis-engage appropriately.
    Make an offer.
    (94-95) PIH harness with computer
    Found this conversion harness among all the other parts I have to replace the "finicky" 1994-1995 ECM with a pre-1994 unit.
    Make a reasonable offer if interested
    >NEW< MPG 5-Liter Windage Tray Kit
    Since it is fundamental that efficient lubrication systems help keep the crankshaft free of unwanted oil, the use of this special windage tray kit is necessary for maximum horsepower.
    This style windage tray is designed to quickly disperse oil leaving the connecting rods and main bearing areas so the large drops of oil do not bounce off the interior of the oil pan back into the spinning crankshaft.
    The tray is made of lightweight 18 guage steel and features a built in adjustable scraper, using a precision contour to create the correct scavenging effect, while improving oil drainback.
    Our heat treated grade 8 extended main cap bolts and nuts are supplied in the kit making this a totally bolt on windage tray with NO other modifications required!
    MPG=89.95
    Bolt on 12 horsepower retaining the stock pan
    $70.00 shipped
    16 Comp cams part #26918 BeeHive springs, etc.
    Comp Cams Beehive springs, 7* steel retainers, steel locks, and springs cups to properly locate the 26918's in a T.W. cylinder head.
    Great condition----- make a reasonable offer
    HAL 175/14 Coil-Over Springs 4 sale
    Coil-Over Springs, 175 lbs./ in. Rate, 14 in. Length, 2.5 in. Diameter, Silver Powdercoated
    * Springs have 10 passes on them.
    * Removed due to combination change.
    * $30.00
    19 lbs/hr. injectors ONLY 30,000 miles on 'em
    8 19 lbs/hr. injectors for sale. EXCELLENT condition.
    $40.00
    >>>55 mm Mass air flow meter LOW MILES<<<
    Factory Mass air meter for sale. 30,xxx miles on this excellent piece.
    $20.00
    5.0L FOX BODY braking system 4 sale
    * All parts listed below have 30,xxx miles on them.
    * Calipers w/ pads, lt./rt. sides w/ rubber hoses
    * Original Ford Rotors(cut once) no warpage in present state (10.87" diameter)
    * Rear Drums
    * Backing Pates w/ wheel cylinders
    * Shoes and hardware for Rear drums
    * Proportioning Valve
    * Parts were removed because of installation of Manual brakes, and Aerospace Components drag race kit.
    * Make an offer.....
    8.8" stuff..(3.27's, driveshaft, 28 spline axles/traction-Lok
    Used 3.27 cogs from a 96 GT that have 15,xxx miles on them. Excellent condition.
    * $25.00
    Stock steel driveshaft from a 1993 GT 30,xxx miles.
    * $30.00
    28 spline stock axles, great condition, 30,xxx miles.
    * $15.00
    28 spline 8.8 Traction-Lok unit, Excellent condition, 30,xxx miles.
    * $20.00
    16 Ford hydraulic roller lifters
    Used and in good condition.
    $25.00 shipped
    1993 LX/GT stock steel hood
    Steel hood painted factory red. Excellent condition with great paint and no dings.
    Make offer.
    Stock front sway bar 5.0L
    *from a 93 GT
    *great for 4-cylinder to V8 conversions
    $10.00
  1. Fox body parts for sale
    By matty g in forum Ford Vehicles
    Last Post: 12-05-2013, 12:43 PM
  2. Fox Body Parts For Sale
    By 89mustang5.0 in forum Ford Vehicles
    Last Post: 05-18-2012, 10:19 PM
  3. Fox body suspension parts 4-Sale
    By bad88t-top in forum Ford Vehicles
    Last Post: 01-30-2010, 09:55 PM
  4. fox body parts for sale
    By ryan319 in forum Ford Vehicles
    Last Post: 07-16-2008, 07:49 AM
  5. Fox body parts for sale here
    Last Post: 11-21-2007, 05:36 PM
