Results 1 to 11 of 11
Thread: check engine light!!
    Senior Member yellowstang03's Avatar
    Dec 2007
    Ligonier PA
    796
    i was driving around last night and my check engine light came on and the codes were
    P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1.
    P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1.
    does anyone know what the cause of that could be?
    03 gt kb
    THis should help,P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit. Electrical:
    Short to VPWR in harness or HO2S
    Water in harness connector
    Open/Shorted HO2S circuit
    Corrosion or poor mating terminals and wiring
    Damaged HO2S
    Damaged PCM
    Fuel System:
    Excessive fuel pressure
    Leaking/contaminated fuel injectors
    Leaking fuel pressure regulator
    Low fuel pressure or running out of fuel
    Vapor recovery system
    Induction System:
    Air leaks after the MAF
    Vacuum Leaks
    PCV system
    Improperly seated engine oil dipstick
    EGR System:
    Leaking gasket
    Stuck EGR valve
    Leaking diaphragm or EVR
    Base Engine:
    Oil overfill
    Cam timing
    Cylinder compression
    Exhaust leaks before or near the HO2S(s)
    A fuel control HO2S PID switching across 0.45 volt from 0.2 to 0.9 volt indicates a normal switching HO2S.
    P1131 - Lack of HO2S-11 Switch, Sensor Indicates Lean A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time. See Possible Causes for DTC P1130
    Dec 2007
    Ligonier PA
    796
    uh oh ha ha looks like it might be a long day....thank you very much for the info
    03 gt kb
    Dec 2007
    Ligonier PA
    796
    actually thinkin about it i was in 4th gear about 4thousand rpm i let off and it started breaking up pretty bad and i didnt know why then i got back on it and it was fine it did seem like it was running out of fuel..
    03 gt kb
    how is it running right now?? something like that is kinda hard to say, i would almost have to have it here to diagnos it..
    Dec 2007
    Ligonier PA
    796
    it seems to run fine now it only broke up like that one time then about 5 minutes later it threw the light on so i cleared it then it came right back on
    03 gt kb
    ooowww, cant really say, would have to have it here to check it out...
    5,822
    didn't you just put longtube headers on? check the connections on your front O2 sensors on both sides... and/or did you put O2 extensions on, too? check all the connections.
    2019 Colorado ZR2
    Dec 2007
    Ligonier PA
    796
    good idea....i did put the extensions on...and also i just got my sct live wire hooked up last night at the same time so who knows what it could be lol
    03 gt kb
    i think one o2 wire is on the engine harness and one is on the tranny harness, so make sure you have em hooked up correct, IE: left/right bank, i think they are color coated..
    Dec 2007
    Ligonier PA
    796
    thanks alot for the info guys. i'll be checking all of it out today ill let you know what i find.
    03 gt kb
  1. check engine light??
    By 07blkfooseGT in forum S197
    Last Post: 05-14-2013, 06:58 PM
  2. check engine light
    By Jeep N Stang in forum The Bar
    Last Post: 09-12-2009, 04:09 PM
  3. PIH harness in 94 check engine light
    By blksunshine88 in forum Fox-SN95
    Last Post: 03-13-2009, 11:28 AM
  4. WTB: Engine Stand + Engine Hoist
    Last Post: 10-16-2008, 01:22 PM
  5. 5.0 engine shroud, battery tray, engine stand
    Last Post: 08-24-2008, 06:54 PM
