Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Winter project thread
    Mt Pleasant, PA
    4,905
    Now that winter is about here, what plans do you have for your car?
    Mt.Pleasant pa 15666
    2,832
    to get one together
    North Hills
    1,229
    turbos are going back on
    robinson
    1,091
    finish putting mine together plus maybe a few goodies
    Banned. shawnsvtcobra's Avatar
    Altoona,Pennsylvania
    2,016
    200 amp alternator, mac cat back, cant take the dumps haa, better gas tank with baffles, and a steel tensioner.
    Kenne Bell Blown 7-UP 9002stang's Avatar
    Imperial
    278
    upper/lower control arms, roll cage, brake upgrades, lowering springs, shocks struts, port my lower cobra intake. And some sticky tires.
    2002 GT- Sold
    2003 F-150 ext cab 5.4l v8 4x4
    1990 7-up vert 346rwhp/414rwtq
    08 Polaris/KTM Outlaw 525 IRS
    Farmington WV
    4,672
    buy a mustang
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    Turbo.
    If everything works as planned, I will have my '95 up and running with the new dart shortblock/AFR heads and quite possibly get my '90GT running with a 5 speed and 5 lug conversion to serve as my track car all by spring.
    If money allows I'll also be doing at least one of the following with the '95:
    1. Buying a stand alone computer (leaning towards the AEM at this point)
    2. Buying a full fuel system (sumped tank, lines, rails, pump, regulator) and possibly injectors
    3. Custom chrome moly roll bar
    I can't put the turbo kit on until I get number 1 and 2. :(
    Got Boost?
    West Mifflin
    1,442
    Im going to go a different route this year. Since its gonna be my final year of college im going to save money for rent and do the move outta my house mod. Ill still be reaing next year but car mods will be put on hold.
    1994 Rio Red GT
    10.60 @122.88
    Sold
    Farmington WV
    4,672
    Quote Originally Posted by Rio94gt View Post
    excellent mod....best one i ever did.
    I like hair dryers Twin01cobra's Avatar
    Wherever I want
    1,270
    I'll be doing twins this year if all goes as planned, if not then I will upgrade my supercharger to a D1 with 8 rib setup at about 18#'s of boost.
    General Douglas McArthur
    Mt Pleasant, PA
    4,905
    Quote Originally Posted by 01cobrasvt View Post
    Whats the wife think about you doing twins? LOL.
    I'll be doing whatever it takes to get my car into the 10's w/ the stock longblock.
    Here's what I have going so far.....
    1. Toss my stock 3.33 pulley in favor of a 2.65 pulley that should put me around 17-18lbs. of boost up from the current 11lbs. I run now.
    2. Install my Foxlake ported gt-40 lower and have my upper ported to match the lower and a new 75mm t.b. up from my old 65mm. t.b.
    3. Lakewood 90/10 struts, and Moroso trick front springs, maybe a QA1 tubulat K-member.
    4. New vlavlesprings for my stock gt-40 irons, new comp cam lifters, and timing chain
    5. Possibly a new 8-point roll cage.
    6. Anderson Mr. Freeze methanol injection kit
    7. Maybe a Vortech T-rex inline pump
    8. A new custom burnt SCT chip by Kayffmans
    If this dosent get me into the 10's then I dont know what will!!
    Rob, do you think you'll have to ditch the 4.10's?
    I dont know, I really hope not. Are you asking that because of the way we thought I was hitting the limiter at the track rental? If so, I believe that I was actually blowing my spark out & not hitting the rev-limiter, because the car pulls just like it use to now that I closed my gap down & got a new ignition coil.
    1. Think I am going to build myself a stroker modular over the winter. Been looking at parts and trying to decide on what to use. Will keep it NA for next season but it must be able to take boost or large nitrous shots in future.
    2. The 4.10s in rear need replaced badly. I have damaged teeth on ring gear. So I'm going to step up to 4.30 or maybe 4.56 gears.
    3. Replace aluminum flywheel with a steel one. I lost way to much in 1/8 this year from the aluminum one.
    4. Go over suspension and change out a few pieces
    5. Install a cage and whatever safety gear I will need.
    6. Goal is 11.0s NA
    Gibsonia PA
    413
    -I want to but new billit contols and 200 rear tire conversion on the Bike\
    -Headers and CD ignition on the truck
    -black Bullitt wheels 17x8 front and 17x10.5 rear with 315 nittos on the stang
    00 Yamaha V Star 1100
    88 Ford F250
    Add A 10 point on my cage,new upper and lower control arms,anti roll bar..battery cutoff, window net,full drag suit,160# injectors,100 shot wet kit,wheelie bars and a parachute,IHRA LIC....shooting for 8's in a street car
    best of 9.66 at 141 MPH
    http://www.mikeymustang.com
    Wrench Wench & GeekGrrl stanggrrl's Avatar
    Monroeville
    321
    Quote Originally Posted by mikeymustang View Post
    I ain't packin' no 'chute!
    Sounds like deja vu all over again.
    It never ends, does it?
    How 'bout his'n hers race cars?
    Alicia*
  1. Another winter project
    Last Post: 01-15-2014, 08:47 PM
  2. Winter project..
    By jaa55 in forum The Bar
    Last Post: 01-27-2013, 08:36 PM
  3. 2010 Winter Olympics thread
    Last Post: 02-17-2010, 09:35 PM
  4. Winter project step 1
    By Rio94gt in forum Fox-SN95
    Last Post: 08-31-2008, 09:50 PM
  5. winter project.......
    Last Post: 11-27-2007, 12:48 PM
