Results 1 to 3 of 3
Thread: Line Lock Help
    Member molnartr's Avatar
    Leechburg
    282
    Line Lock Help
    I am installing a summit line lock on my car (93 lx) and I wanted to check to make sure I was doing it right. Summit supplied one set of directions, the hurst install kit tells me a different way and then I found some different ways on the net. http://www.motorsportsdigest.com/tech/install2.htm
    I know fox body cars are different from most because both front brake lines go to the master cyl.
    I am pretty sure I know the right way now but I wanted to make sure. So if anyone can post any suggestions or pictures I would appreciate it.
    Thanks, Tim
    _________________________________________
    My rides:
    1993 LX Stang - SOLD Stangless for now.
    4.10 gears - Hurst Shifter - King cobra clutch - 65mm tb - BBK cold air intake - BBK offroad h pipe - flowmasters - BBK fuel pump - underdirve pullies - Ford racing wires - Lakewood DS loop - Summit line lock.
    2005 GMC Sierra
    5.3L K&N Filter and Flowmaster pipes
    20" Verde Wheels and lots of chrome
    DD - gas hog
    I think my 84 is different than your 93. I have two ports (one front one rear) off the master cylinder, and three off the proportioing valve. For mine, it was plug one line off the proportioning valve, run the other to the line lock. Then used two ports off the line lock to run back to the lines that go to each front wheel. The trick is, you want the line lock AFTER the proportioning valve IMO.
    If you have two ports off the master cyclinder for the fronts, I think you still plug one.
    Some instructions will show the line lock right off the master cylinder, and I've not heard good things about that. The proportionag valve comes into play and causes issues. I know mine works flawless, and I dont know how I lived without it :D
    Bob Myers
    Senior Member Hawkeye's Avatar
    Plum
    605
  1. Line lock question
    By mustang50lx in forum General Tech
    Last Post: 03-10-2009, 08:24 PM
  2. Where do you have your Fox line lock mounted?
    Last Post: 02-22-2009, 08:14 PM
  3. line lock
    By tylerstepp in forum Ford Parts
    Last Post: 01-23-2008, 11:40 PM
  4. WTB: Line Lock
    By Mitternacht in forum Ford Parts
    Last Post: 12-10-2007, 10:50 PM
  5. NEW SLP line lock 99-04 stangs
    By Chris00GT in forum Ford Vehicles
    Last Post: 01-12-2007, 11:21 PM
