Started my 5 lug swap today.Back end went easy,front was very different,found 2 bad ball joints and a cracked brake hose.Glad I found it now and not half way to Carlisle!!
cool,what wheels you going with?
02 MG GT
98 SVT Contour SF/MNB #2059
93 Civic Hatch
Its about time robert!!!
I bought a set of 99 cobra wheels from smallville. I really like the way they look on the notch.
Can't wait to see how it looks.![]()
nice, did you go with sn95 spindles and ranger axles? should look killer
Yea,I did the sn 95 front and ranger rear. since I need ball joints I'm going to use 94 ones that way I don't have to stack washers. I'm going to change the tie rod ends too seein I'm this far and it needs lined up anyway.
What are you planning on doing with the old 4 lug wheels?? If you are interested in parting with them let me know......![]()
CHRIS is the name.......
I had oz comp wheels with nitto 555's and drag radials. made 1 call and they were gone.
Steeda sells a set of balljoints that is perfect for the SN95 swap.
I need to pick up a set myself. I just picked up the SN95 spindles and I have a set of 97 Cobra Rear axles I'll use on a Turbocoupe Rear End.
I just need a set of four Rotors, front dust shields and calipers.
The wheels are 17".Had another problem,the plug to fill rear end was rounded off ,tried the heat wrench and still wont move.But I just happen to have a trick flow rear cover with a fill plug.Finished it up tonight.
Curious if the SN95 Dust shield are the same 1994-2004. Did you replace yours?
I got new ones from ford for the 94 spindles,they fit fine.By the way I have 2 ball joints for a 94 if you're doing a swap no need to use spacers and alot cheaper than steeda 40.00 for the pair
