Results 1 to 12 of 12
Thread: Automatic Transmission. Flush vs filter/fluid change
    I was talking to some one regarding getting my AOD on my Explorer serviced. Strong believer in having filter / fluid changed on a AOD transmission on a regular basis. I stopped in a place in New Kensington to get a price and he told me they no longer remove the transmission filter but they have a process that flushed out the transmission, fliter and torque converter.
    Anyone heard of this? Comments, Yes, No, Maybe?
    How good is this process vs. the R&R of the filter/fluid?
    Senior Member casper gt's Avatar
    Oct 2007
    creighton pa
    260
    trans
    although it is not a very good idea not to drop the pan,most places do it that way now. if you want the job done right & your close to new ken. stop by my shop in cheswick & we will fix you up.
    pa
    860
    Do the flush! you can't do it any better than that.. Its the best way to get the tranny fully cleaned out..I do them all the time with great results. Go see casper gt.
    What about the filter? Can the flushing damage the filter at all?
    What a vehicle that is 10 years+ old? Could that older filter get messed up?
    pa
    860
    Doesn't hurt the filter. Only uses the tranny pressure to flush it out. The car runs and pushes out the old while the machine puts in the new stuff. They should put some tranny cleaner in there and take it for a ride so it cleans the plates and loosens up all the junk. Then they will hook it up to the tranny line so it flushes out the tranny, rad and the lines. You will feel the difference.
    GREEN=FAST sweeney1030's Avatar
    johnstown
    570
    the filter is'nt really a filter in the 02 and up exploders , they are more like screen mesh over laped. when you back flush them every thing comes out. if you do drop the pan there is no way to add fluid except to squirt it through the over flow type drain plug they use and that is a huge mess.
    The Explorer is a 1995. That why I was concerned about the age of the filter. If the flush is good, that may be the way to go.
    pa
    860
    OH yeah... its the way to go.. I had trannys that would shift, stayed in drive all the way down to 10mph and would come out. Put the cleaner in it and drove it for a few miles. Boom, starts to shift. Flushed the tranny out for them and seen them a few months later and the said it was shifting good.
    How much does a flush go for? Is there a price difference by size? Example a Honda vs an Explorer?
    pa
    860
    Yeah, some time it depends on how many quarts of fluid it takes. We charge any where from 90 to 140..
  1. Replies: 6
    Last Post: 03-25-2013, 06:11 AM
  2. new radiator - need to flush
    By Warrior1670 in forum General Tech
    Last Post: 06-20-2011, 02:32 PM
  3. Free: 03/04 cobra K&N filter & oil filter
    By KBCobra in forum Ford Vehicles
    Last Post: 08-30-2010, 01:29 PM
  4. Transmission Fluid question
    By 2000GT in forum The Bar
    Last Post: 03-27-2009, 02:24 PM
  5. C6 Transmission Fluid, Which kind?
    By Big408 in forum The Bar
    Last Post: 06-19-2008, 05:07 PM
