since this has become a popular tire, figured post up some info on them
Proper use of Mickey Thompson ET Street Radial
Inflation Pressures
On the racetrack DO NOT use starting pressures below 11 psi.
Recommend pressures for:
P295 and larger sizes: 11-14 psi
P275 and smaller sizes: 12-16 psi
On the highway we recommend running 75% of the max psi as notes on the sidewall of the tire.
Burnouts
The tread compound used in the ET Street Radials is designed to heat quickly and does not require a heavy burnout. Continue the burnout until the engine starts to pull down. We do not recommend a dry hop after the burnout.
Bead/Wheel Slippage
Some bead/wheel slippage may result during the course of a 1/4 mile (or 1/8 mile) drag race. This is normal.
Use of Bead Screws
If you elect to use bead screws, we recommend the installation of 16 equally spaced screws per bead.
Bead-Lock Wheels
For drag strip speeds in excess of 180 mph, Bead-lock wheels are highly recommended.
This is Mickey Thompson STREET & STRIP TECH BULLETINS Technical Bulletin #7. For more information regarding Mickey Thompson Performance Products ph: 330.928.9092
__________________
