Thread: ? on fuse link for fox body engine harness
    formerly 93teal PSPstang's Avatar
    1,164
    anyone have any idea what this blue wire/fuse link does or is for??
    is part of the engine harness at pass side near hood hinge.
    i took pics of the car that has one, and my car that is missing its...
    Oh dear thehill63's Avatar
    Feb 2008
    Cranberry Twp
    430
    ITS A BOMB!!! DONT CUT THE BLUE WIRE!
    lawl? i have no idea
    Stupid question, but what made you look for it? Might make it easier to figure out. Any idea what circuit its tied into? EVTM is your friend, I only have them for the older fox's or we could start sorting.
    Bob Myers
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    im almost positive that is the wire and fuseable link for the o2 sensors
    1,164
    Bob Myers
    when i bought this thing some rigged up a push button starter to it. wired directly to solnoid.
    works great except when you hook up the red/blue wire to starter solnoid top how it should be and use the key.
    car won't start. i then discovered the starter/neutral switch on clutch pedal was missing. i put one in-still no start.
    changed ignition switch still no good.
    also checked starter solnoid itself. its good.
    now at least when i try starting the car with a key i am getting a clicking noise coming from the pass side relay under the mass air meter. thats what brought me over there and i noticed the missing fusible link
    i have been going over every freaking wire on this car to look for cut wires etc
    i have the dash out now to look at wires and also to change the heater core and put a nicer dash shell in the car.
    the car is a 91 but i did order a 93 evtm for my other cars, so that may work.
    bob, if you're up for a little troubleshooting give me a PM. i have a few days into working on this thing now!!
    Quote Originally Posted by PSPstang View Post
    You know the answer here, if its been messed with as much as it sounds like, you need to wring out circuits based on the EVTM and just go at it that way. Not likely to find it just looking for the changes.
    Confirm that power is going into, then out of the clutch switch as a first step. The other thing to try is to turn on the key (power up) then jump the solenoid itself. If its starts, the issue is in the interlock circuit if I remeber how it works correctly.
    PM sent.
    Bob Myers
  1. Fox Body Suspension and Engine Parts for Sale
    By 50stang in forum Ford Vehicles
    Last Post: 05-28-2013, 05:39 PM
  2. C6 vette mega fuse/fusible link
    By jaa55 in forum Corvette
    Last Post: 03-16-2013, 09:39 AM
  3. F/S 92-93 Mustang 5.0 engine harness
    Last Post: 08-02-2012, 08:49 AM
  4. WTB for fox 90 metal plate around fuse box
    By fran in forum Ford Parts
    Last Post: 03-12-2012, 01:53 PM
  5. wtb 89 engine harness 5.0
    By went9s in forum Ford Vehicles
    Last Post: 09-04-2006, 08:59 AM
