Results 1 to 11 of 11
Thread: Intake Questions????
    Marine Eng. Officer ArmyWarrant's Avatar
    Fort Eustis, VA
    525
    I currently have a Victor Jr Intake on my 306 with a 600 CFM Holley Double Pumper. Its a single plane intake and I am wondering if it would be better to go with a dual plane due to my car seeing mainly street driving. What benefits / negatives would I see in swapping to like a performer rpm?
    The car has a 306 with stock heads (as far as I know), Z cam, BBK Shorties, BBK Offroad H pipe and 2 chamber flows.
    90 GT stock needing some minor work, traded my 87 Vert to my bro for it.
    2004 RAM 1500 Quad Cab Hemi DD Gonna be up for sale soon
    86 Notch New Project
    Spoon Killer HidalgoGT's Avatar
    Uniontown
    1,792
    Quote Originally Posted by ArmyWarrant View Post
    Only thing I could tell ya from my chevy days is I always liked the single plane intakes better. The dual planes have become better but, I still think the singles givemore performance over all. You might pick up a lil torque on the bottom end with a performer rpm. But for the price of the swap it isnt worth it to me.
    Fort Eustis, VA
    525
    I also just read that it is recommended to run a 750 or bigger carb on a victor jr. 750 cfm is to big for my engine, Anyone else have any suggestions thx Hidalgo
    Uniontown
    1,792
    How is the car running with the current set up? I used to run an old torker with a 600 douple pumper and it worked ok. I run a 750 dbl pumper on a dual plane with a 1" spacer(intake came on the motor not my choice so I added the spacer). Plan to put a victor jr on it when I redo the truck. If your car runs fine now and doesnt load up or bog then I wouldnt worry about it much. If you knew someone who had one laying around you could try a swap to see if you gain anything. Being your heads aren't large port heads I dont think you have to worry about the 750 recomendation.
    Fort Eustis, VA
    525
    It doesn't bog or anything I will stick with it for now and see how it does. Thx
    Fort Eustis, VA
    525
    Well I pulled the valve covers today and found some good things, they are not stock heads. They are World Products Victor Jrs with stud mount roller rockers. I keep finding more and more good things about the car the more I check it out.
    Uniontown
    1,792
    Could be why you havent had any issues. Other thing you could do is get a temp. gun and check each header tube see if any are hotter then the other front/back and adjust for that if the carb has the 4 corner idle screws. Seems like the combo is running well. Had it to the track yet?
    Fort Eustis, VA
    525
    Quote Originally Posted by HidalgoGT View Post
    I haven't had it to the track yet? It's an hour and a half drive to the nearest track. I want to try to get to the track this summer and see how it does.
    The carb only has the 2 idle screw that i've seen so thats not an option. I am going to rejet it with a friends recommendations and see how it does.
    Uniontown
    1,792
    Ya PRP is about 45 mins give or take a cop or two.
    Fort Eustis, VA
    525
    Well I drove it for the first time on the highway and wow what a difference it makes when you have a car that is built right and no shody machine shop work. This thing pulls great all the way through the RPM range and I didn't even get over 5500 rpm in it.
    All that is left is to get the carb jetted to better match the setup. It smells like it is running rich and every once in a while it puffs a lil smoke when its been idling for a while like its loading up.
    Junior Member
    8
    this is why the vic jr works on that small inch motor.
  1. 5.0 questions
    By geps91stang in forum Fox-SN95
    Last Post: 06-13-2012, 06:51 PM
  2. WTB: Bullitt Intake or upgrade from PI intake
    By dpstang98gt in forum Ford Parts
    Last Post: 10-08-2009, 01:49 AM
  3. questions
    By M-dubb in forum General Tech
    Last Post: 07-03-2008, 11:17 AM
  4. some 99-04 questions
    By Inkdcountryboy in forum General Tech
    Last Post: 04-22-2008, 03:03 AM
