Results 1 to 20 of 30
Thread: Fuel pressure question - NA EFI 347
    North Hills of Pittsburgh
    430
    Is 46 too high with all the vacuum lines connected? My car idles the best, makes the most vacuum at idle, and drives just fine at 46.
    I have 42 lb injectors, 90mm LMAF. My car has a custom tune for my old NA 347. My new combo has a AFM-B41 (old was TFS-2), new Systemax 2 (old was TFS R Series), new Hooker 1 5/8 super comps LT's (old BBK eq length shorties).
    I know the 42's were adjusted way down in the custom tune for the old combo. The tune is the same, but the new combo seems to like 46. I wanted to find out if 46 could cause rubber fuel line bursting or other problems. I'm taking a long drive up to U'town for some work by Tim this Saturday. I don't want to have any problems. Thanks.
    2016 GT Premium
    I'd say you're fine. I always set mine around 44 psi.
    You don't need to worry about bursting anything. Any car that you have seen with a blower and an FMU is likely seeing 60-100psi under boost. I'm running 45psi base pressure on my 331 with 24's. Unless you pulsewidths are very small via the chip, that seems like an awefully lot of FP to be running with your combo and 42's. The only way to know is via a wideband.
    Yeah, Paul is right. Under boost, I am getting real high pressure. Just need to get that tune real soon. HAHAHA
    GOT RUMBLE??? Balaska347's Avatar
    Jan 2007
    Belle Vernon
    1,294
    Yeah you definitely won't hurt any except for HP. Thats a lot of fuel for that combo. I would bet on a dyno your A/F would be down in the 11.0 range if not lower.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    430
    Now you have me thinking I should lower the fuel pressure. I pulled a spark plug and the insulator was real white, but with the hotter ignitions you can't tell much by that. I am debating whether to get a wideband or a new tune - they both cost about the same price.
    2016 GT Premium
    Get both Bob. I love the wideband.
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    the aem is just a 2 1/16 gauge and it has removable faces and bezels so u can pick which u like best
    Petersburg,PA. 16669
    816
    any reason you chose 42's?
    I'd go back to 30's and retune
    I had a more agressive setup that what you have and 30's were plenty
    Just something to think about
    This is why I like a pms and wideband because if you make changes you don't have to go runnig back to the dyno all the time,just change some numbers and go but to each his own.A dyno tuned car works fine too
    88 GT...and some boost
    430
    Quote Originally Posted by 349Stroker View Post
    Don Lasota, my 1st tuner told me he could tone down the pulse with the tune so the 42 were no big deal. Also, i got a great deal on the 42's and 90mm LMAF for $349 through buyfordracing.com.
    I've thought about the pms as an option. Rick A. told me the PMS will not allow me to tune out the hanging idle that occurs when you put a cam in the 94/94 cars. You also cannot turn off the CEL or disable the EGR functions via the PMS. I would probably go with one if it had more flexibility in those 2 areas.
    Rick A. also told me the LMAF won't work with his PMS so I would need to buy one of those.
    I assume you are happy with your PMS. Do you have an aftermarket cam and any hanging idle problems?
    2016 GT Premium
    Jan 2007
    Belle Vernon
    1,294
    Did you ask Rick A. about a wideband for a NA motor? He will tell you that you are wasting your money. He knows what he is talking about.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    430
    Quote Originally Posted by Balaska347 View Post
    No, but he did tell me that an NA car will lay down if it runs out of fuel and that I won't hurt the engine even if it did.
    2016 GT Premium
    Jan 2007
    Belle Vernon
    1,294
    Exactly a NA car won't hurt itself from being to lean it just won't make power. A power adder car will keep making more hp as you lean it out until it blows itself up thats why the wideband will help them. For a NA car it is pretty much a waste unless you enjoy watching the gauge. It's all driver preference.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    816
    I can't see how it is a waste.Still have to tune a N/A car and my pms and wideband did great on my 349
    That made 435 rwhp at 12.2 a/f
    The guy I sold it to dynoed it and got those #'s but hasn't been back to thre dyno since to lean it out.I never dynoed the car I just tuned it with pms and a wideband
    Jan 2007
    Belle Vernon
    1,294
    The reason I say its a waste is because I bet I could have made the same 435 maybe only 430 without the $900 PMS and a $300 wideband with the car on a dyno with a a/f reading. So I could have saved $1100.
    Philly what are you confused about?
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    816
    Mine being a 88 I don't have an idle issue like yours
    I have a B41 in my car as well but I am runnig a 306 with an S trim now.
    I had a stage 3 trickflow cam in my 349 and it worked great
    Yea the 90mm meter wouldn't work.I use a 95mm PMAS velocity
  1. WTB: EFI Fuel Pressure Gauge
    By Dan B. in forum Ford Parts
    Last Post: 11-22-2011, 08:37 PM
  2. question on fuel pressure
    By vitaleffects626 in forum General Tech
    Last Post: 05-05-2011, 11:04 PM
  3. Crane Adj. fuel pressure regulator for 86-93 EFI fox
    Last Post: 03-05-2008, 02:57 AM
  4. Fuel pressure gauge question
    Last Post: 10-23-2007, 05:17 PM
  5. N/A EFI 347 c.i.d. (VIDEO) Mid 10's
    By Pure Stock in forum Pictures & Videos
    Last Post: 08-23-2007, 07:01 AM
