Results 1 to 10 of 10
Thread: Rear end problem??
    Selinsgrove, PA
    526
    Rear end problem??
    Ok, well in my other post i asked about my tire wearing really weird, and got an answer that it could be a bent tube, or a bad axle bearing... is there anyway to check either of these? (my tires were also WAY under inflated) or could it have just been that?
    Mustangs..
    Fox/n.
    tires
    It could be a inflation prob, but usally not on one edge, like it would be both sides, or middle, but thats what i think... just a opinion.... c'mon guys help this guy out
    JUNK IT!
    rear
    Are you sure that thing isnt bent and thats what is vibrating???
    JUNK IT!
    Member molnartr's Avatar
    Leechburg
    282
    Jack the car up take the wheel off and check to see if there is any play when you move the axle up and down or side to side.
    Not sure how many miles are on your car but it is over 20 years old so a bad axle bearing is not out of the question.
    _________________________________________
    My rides:
    1993 LX Stang - SOLD Stangless for now.
    4.10 gears - Hurst Shifter - King cobra clutch - 65mm tb - BBK cold air intake - BBK offroad h pipe - flowmasters - BBK fuel pump - underdirve pullies - Ford racing wires - Lakewood DS loop - Summit line lock.
    2005 GMC Sierra
    5.3L K&N Filter and Flowmaster pipes
    20" Verde Wheels and lots of chrome
    DD - gas hog
    Selinsgrove, PA
    526
    like if i jack it up and let the wheel on and pull on the wheel it moves a little, but then again both sides do this...
    Fox/n.
    Leechburg
    282
    the wheel will move a little, take the wheel of and move the end of the axle where the wheel studs are. Move it up and down and side to side. If there is alot of play it could be a bad axle bearing, however since your air pressure was so low that is probably why the tire was wearing on the outside.
    But there is still the vibration
    My rides:
    2005 GMC Sierra
    DD - gas hog
    Selinsgrove, PA
    526
    yes but it was only wearing on the outer edge, not both outer edges... so i dont think it was underinflation, because both tires were, and only one is wearing..
    Fox/n.
    88 5.0 lx conv eddmann55's Avatar
    irwin
    538
    Inflate the tires heavily, do a burnout and look at the pattern. worth a shot?
    Selinsgrove, PA
    526
    ok i just looked, and both sides of my rear tire are worn.. not just one outer edge, both edges of the tire are really worn.. so i guess its not my axle bearing, it was just underinflation???
    THANK GOD!!
    Fox/n.
    Leechburg
    282
    My rides:
    2005 GMC Sierra
    DD - gas hog
  1. 96 Gt rear end
    By 00Sixer in forum Ford Vehicles
    Last Post: 06-15-2012, 03:14 PM
  2. 8.8 rear end.
    By NateSVT in forum Ford Parts
    Last Post: 08-01-2011, 09:51 AM
  3. Need help! Rear end
    By Darren in forum Wolfpack Speed
    Last Post: 01-24-2011, 03:44 PM
  4. need help with rear end please!
    By LatrobeStang01 in forum General Tech
    Last Post: 08-15-2009, 07:10 PM
  5. rear end?
    Last Post: 07-13-2008, 07:55 PM
