Results 1 to 13 of 13
Thread: problem with start up, sometimes
    Bridgeville
    1,278
    Exclamation problem with start up, sometimes
    ok so sometimes when i start it up, it doesnt have to be a cold start, just any time i go into a store and comeback every once in a while, i will start it and it either wont start, or it turns over rpms go up a lil and then it dies. also sometimes when i am at a stop sign it spudders a little like its going to stall. all of these dont hapeen all the time just once in a while and i have not a clue of what it could be, has anyone experienced anything like this? do i need a dyno tune? thats the only thing i can think of.
    anything will help, thanks
    5,822
    Quote Originally Posted by PunisherStang View Post
    mine did that sometimes after my cam-install and my cam is somewhat milder than yours. SGS fixed that right up. It starts and runs almost too smooth now.
    EDIT: or just get one of these and have your civic buddy tune it for you !!!
    2019 Colorado ZR2
    3,316
    if the problem appears random, the first thing I would check is sensors and sensor wiring for a loose connection if you havent done so.
    Ligonier, PA
    6,365
    from my own experience id have to say IAC valve. there like 50 bucks at autozone and make a huge difference.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Senior Member dpstang98gt's Avatar
    Feb 2008
    East Liverpool, Ohio
    620
    ya i would say your IAC valve happened to me too
    1998 TT GT....
    1998 Honda Civic Stock DD
    1994 Jeep Grand Cherokee, 4 inch rough country suspension lift and BFG 32 inch M/Ts
    2000 Seadoo RX Millenium Edition 951
    Polar Vortex
    6,031
    Iac, try taking it off then spraying the inside with Tb/carb cleaner. I took needle nose pliers and wiggled the plunger back and forth till it moved smoothly.
    Bridgeville
    1,278
    troll, i do have the sct2 programmer lol and i will get that iac valve checked.
    Morgantown WV.
    563
    Like others have said try cleaning the IAC valve. Been cleaning mine for 8 years now. lol
    665/540 New times coming
    5,822
    that's the SCT 3. you can get in more trouble with that one.
    definitely check the IAC first because that's a much easier solution, but I'm telling you mine did the same exact thing before I got it tuned. intermittent problems on starts up and the idle would go from 400 to 1,100 SOMETIMES. good luck.
    2019 Colorado ZR2
    '00 Stang
    Oct 2007
    Bridgeville
    229
    iac is probably right....same thing happened with my car last summer.
    runs perfect now
    Ligonier, PA
    6,365
    dont even bother cleaning it just get a new one, cleaning it is barely even a band aid fix and wont last long at all, its very easy to change two bolts thats it.
    1991 BMW 325iX
    1978 Ford F150
    Polar Vortex
    6,031
    Quote Originally Posted by 2001GTTT View Post
    Doesn't hurt to try. Clean it and see if it still acts up, if it does replace it.
    Ligonier, PA
    6,365
    ah i didnt see your post man, that wasnt directed towards you in any way.....just that ive tried that in the past and it tends to still go downhill lol.
    1991 BMW 325iX
    1978 Ford F150
  1. HELP no start--- sort of
    By tbird88 in forum Other Ford
    Last Post: 06-30-2012, 11:36 PM
  2. First Start W/Paxton
    By SAC81 in forum Pictures & Videos
    Last Post: 05-27-2011, 11:35 PM
  3. 97 Cobra no start
    By OCRnotch in forum SN95-New Edge
    Last Post: 03-14-2011, 12:02 AM
  4. '89 Ranger No start problem
    Last Post: 04-03-2008, 10:52 PM
  5. 95 Gt Won't Start
    By 955.0 in forum Fox-SN95
    Last Post: 09-27-2007, 12:16 PM
