What does it take? I am thinking about taking out the 4cyl out of the car and putting in a stock 5.0.. Whats it all take?
A cheap donor car from How Much or Chuck94![]()
I have a good donor car at the house, stop by tomorrow.![]()
definatly would be easier to get a donor car scott this way your not tryin to find parts here and there...
to make it a true complete v8 not only do you need to change the motor and wiring (unless goin carb) you need to change fuel lines,rearend (can use 7.5 but 8.8 will hold together better) suspension (also can use 4cyl suspension just wont handle as good)
4banger suspension is good for drag racing.![]()
i was going to do the motor first, then grab up a explorer rear cause i think they come with 3.73s? and while i was doing that throw 5 lug on it.
Have you considered just selling the 4 xcylinder car and buying a 5.0 car to start? I only ask, because by the time you figure the value of your car, the cost of the donor, and then what all you need to do to make it "right", you might be able to score a decent car for the same value.
I see way to many of these type of projects for sale unfinished, or really tough to sell in the end because they dont have all of the 5,0 stuff.
Just a thought.
i thought about that, but have not seen any interest in the car since i have had it out for sale
I did the swap on my 91 notch. Picked the car up for a little over $500 and in good shape other than faded paint. Then I just started looking on e-bay for parts like PCM, and engine wire harness. Now the car as H/C/I, 5 lug, and I'm almost done swaping from an AOD to a TKO-600.
Chris Kauffman
1988 408LX drag car
If im not mistaken you can use your 4cyl dash harness and get a 89 mass air engine harness and a computer and that thing will be done, ive done these swaps more than once and they aint all that badLet me know if you need a hand swapin that thing, supply beer and im there!!!!!!!!!!!
JUNK IT!
bump need to bring this back.. What all we will need to swap.. This is what i am getting so far
Motor
tranny
89GT wiring harness/comp
rear-end
fuel lines
am i missing something?
k member in a 4cyl car is the same
leave the 4 cyl struts and shocks on it for now
an Explorer rear end isn't the right length so you need a mustang 8.8
you can also get a 87-88 harness V8 harness and convert it to mass air if you can't find an 89 harness
88 GT...and some boost
you will also need V8 efi fuel lines from front to back
