Results 1 to 7 of 7
Thread: electrical problems RND 2
    1,164
    ok, so i still can't get my car to turn over with key.
    it arrived here with some half ass push button starter wired directly to the starter solnoid to start car with key in run position.
    when the key was used by itself and how it should be nothing would happen.
    my engine harness had one burned out fusible link+other iffy stuff.
    yesterday and today i swapped both my engine and dash harness from another same year 5.0.
    still no key start. i turn the key-can hear the fuel pump turn on and fuel pump relay clicks.. thats it.
    any suggestions? i am thinking maybe the computer may be bad or something?
    Petersburg,PA. 16669
    816
    my car apparently had the same problem because my car has a push button start.I don't have power to the re/green wire that goes to the solenoid when I turn the key forward.
    I haven't had time to fix that yet but it works fine with the button
    88 GT...and some boost
    1,164
    yes just bugs the crap out of me and since i have the dash out for heater core swap i want to try and fix it right.
    Member DING's Avatar
    New Bern, NC
    324
    Is the ingintion switch engaging correctly intermally? The reason I ask is because I bought a car with a simular problem and who ever had it before me took apart the switch and reassemled it incorrectly. I shot wires for a few days for nothing. It got power in some parts of the switch that is what through me.
    Hank
    1,164
    i tried two ignition switches, one being new with the same result.
    Did you check what I suggested in the other thread? Do you have power into, then out of the clutch interlock switch?
    1,164
    no, i even have a jumper for the clutch switch i pulled off an auto car, to rule out if my clutch switch was bad
  1. Electrical Questions
    By Tony71502 in forum General Tech
    Last Post: 08-11-2009, 02:14 PM
  2. Electrical issue
    Last Post: 01-02-2009, 08:21 PM
  3. Electrical Help.
    By Rio94gt in forum General Tech
    Last Post: 05-24-2007, 06:51 PM
  4. i have electrical problems too
    Last Post: 05-11-2007, 01:34 PM
  5. Electrical Issue
    Last Post: 05-10-2007, 11:15 PM
