Results 1 to 13 of 13
Thread: '93 Black Hatchback
    Junior Member
    14
    '93 Black Hatchback
    Ok, Up for sale is my recently completed project car. It is a 1993 ford mustang lx hatchback. Original 5.0 with a 5 speed and sunroof. The car has been completely rebuilt. It only needs repainted and some interior work(such as new carpet and floormats) to be perfect. Car is 90% new parts. It is totally driveable. The engine idles smoothly and starts up quick every time even when warmed up. The car was a rolling chassis when I purchased it. The odometer read 30,000 miles on it, but it could have rolled over once or twice. Everything else has only 125 miles on it since the rebuild. Reason for selling is that I am tired of fox bodies and want to get a newer mustang. I am asking Best Offer for the car. I will be getting a clear title in the mail for the car in the next couple weeks.
    Engine
    Stock low mileage shortblock rebuilt by Fox Lake (bores honed, crank journals polished, pistons flycut for larger valves, new clevite bearings, sealed power moly piston rings, arp main studs and rod bolts, canton main support)
    Trick Flow twisted wedge heads
    ARP head bolts
    Speed Pro Cam (222*/232* duration@.050" .510"/.534" lift)
    Comp Cams timing chain
    Trick Flow pushrods
    FRPP hydraulic lifters
    FMS 1.6 stud mounted roller rockers
    Edelbrock ported lower intake
    Typhoon upper intake
    30lb injectors
    '94/'95 fuel rails
    Holley adjustable fuel psi regulator
    BBK 70mm tb
    Pro-M air intake and MAF(calibrated for 30lb)
    Trick Flow black valvecovers
    FRPP water pump
    March Underdrive pulleys
    Mac ceramic coated shorty headers
    Mac offroad h-pipe
    Dynomax ultra-flo catback
    stock radiator
    new radiator hoses
    all new sensors
    Flexalite black magic electric fan
    urethane motor mounts
    Ford stock style oil pump
    Canton 7 quart oil pan
    Professional Products harmonic balancer
    new belt and alternator
    MSD 6AL, blaster coil, cap and rotor
    FRPP 9mm plug wires
    Drivetrain
    New cast flywheel
    King Cobra clutch
    Hurst shifter
    stock t5- shifts great
    FRPP aluminum driveshaft
    FRPP 3.73 gears
    Rebuilt traction-lok (FRPP carbon fiber clutch kit)
    FRPP rearend girdle
    stock 28 spline axles
    Front Suspension
    Stock springs-one coil cut
    Strange adjustable struts
    New ball joints
    Rear Suspension
    FRPP upper control arms
    Steeda billet aluminum weight jacker lower control arms
    Eibach drag springs
    Lakewood 50/50 shocks
    New upper axle bushings
    Reinforced lower torque boxes
    Other
    Maximum Motorsports Full length subframe connectors
    New rear brake shoes
    New slotted front rotors and brake pads
    Hurst line loc
    Stock gt turbine wheels with all new tires
    Single 2 5/8" guage cowl panel with a fuel psi guage
    2 5/8" oil psi guage inside car-not mounted but functional
    Parts that come with car
    Moser 28 spline axles
    A set of 3 inch ARP wheel studs
    Dual 2 5/8" a pillar guage pod
    Call814-251-5044
    Emailbryandgillam@hotmail.com
    Junior Member
    14
    Junior Member
    14
    I am considering parting out the car in 3 sections: Complete motor, transmission, rolling chassis. Let me know what you are interested in.
    I'll take the oil filler tube if you want to sell it. Pm me a price.
    Junior Member
    14
    No, I want to try to sell the whole motor complete first, before I part it out by piece.
    Uniontown
    1,792
    How much for the motor?
    Got Smoke?
    Junior Member
    14
    $4500 will buy everything listed under the engine category except the ceramic coated headers which I no longer have.
    Junior Member
    14
    I could throw in the clutch and flywheel also.
    Junior Member
    14
    the engine will include all accessories as well.
    here is a video of the engine running: http://s81.photobucket.com/albums/j2...t=mustang2.flv
    Junior Member
    14
    Ok, I am going to try and part out the car in 3 ways:
    Everything listed under Engine for
    $4500
    Transmission w/clutch, flywheel, shifter,separator plate, and aluminum driveshaft $1000
    Rolling Chassis Make Offer
    where are you located? how much would you take for the car as is?
    Junior Member
    14
    I am located near Huntingdon, PA 16652. I would like to get $7000 for the whole car complete. It needs an inspection and alignment. I can get that done for you, if you are interested.
    Or do you want just the rolling chassis? $2000 is the lowest I will go on the roller. It has a built rearend with only 125 miles on it. New rear control arms. New front struts and ball joints. All wiring for the v8 except I will keep the msd 6al box. Has a hurst line lock. New brakes front and rear.
    that's more than i want to spend right now. thanks and good luck.
  1. For Sale: 79 - 93 Hatchback black headliner
    Last Post: 11-13-2011, 10:18 PM
  2. Fox body hatchback black seat belts
    By roush08 in forum Ford Vehicles
    Last Post: 03-16-2011, 11:01 AM
  3. 1989 BLACK LX 5.0 5spd. 2.73's hatchback
    By thebreeze72 in forum Ford Vehicles
    Last Post: 08-12-2009, 08:48 AM
  4. FS:black headliner for foxbody hatchback
    Last Post: 08-06-2009, 06:37 PM
  5. FS:front/rear black 4 cyl seats hatchback
    Last Post: 07-28-2008, 03:37 PM
