Results 1 to 17 of 17
Thread: Need some ideas here?????
    SN95 POWER 1994cobra's Avatar
    washington
    158
    Ok here is the problem.Two weeks ago I go to PRP and run a 14.2@ 97 with stock gears (3.08's) Now I go there today after installing 4.10's and run a 14.2@98. My 60 ft. time is awesome now(1.8) and 1/8th mile time is way improved,but after that its like peaked out it and wants 5th gear right at the finish line.My question is how do i get some more top end without changing gears again????
    Got Boost?
    West Mifflin
    1,442
    What was your 60' with the 3.08s?
    1994 Rio Red GT
    10.60 @122.88
    Sold
    washington
    158
    Average around a 2.3
    Got Boost?
    West Mifflin
    1,442
    Something isnt right. Generally every .1 in the 60' is good for .2 tenths off the 1/4.
    Doing that you should be in the mid to low 13s since you dropped your 60' by .5.
    Check your timing, maybe change plugs and wires. Your car must be dead on top end.
    1994 Rio Red GT
    10.60 @122.88
    Sold
    washington
    158
    Thats a good start.I will try some new plugs and wires and see whats up from there.Its insane i can be ahead by a good car length at the 1/8th mile and just watch em pull away.Thanks man
    Got Boost?
    West Mifflin
    1,442
    Check that timing as well. Good luck with it.
    1994 Rio Red GT
    10.60 @122.88
    Sold
    347cobra schiavon8241's Avatar
    pittsburgh, pa
    178
    if your still curious about this. i would have to say timing issue on this. i had the same thing going on when i put on my slicks. my 60ft dropped from a 2.3 to a 1.6 with the slicks but my times wernt dropping at all. i bumped my timing up a few degrees ran 110 and lost half a second.
    washington
    158
    The timing is all good and since then I have redone the whole ignition and that helped a lot.Next week Tim is taking out the smog stuff,a/c,and putting on a set of long tubes.I will be at the next TNT and see where I am at after that.
    1994 svt cobra BBK underdrive pullies,cold air kit,long tube headers,Hurst shifter,4.10 gears,msd ignition,catless flowmaster exhaust,custom "Rodeheavers"subframe connectors,smog pump and a/c delete.
    Stangman Stangman's Avatar
    North Hills
    234
    Did you run out of breath...meaning going thru the traps at a RPM that your engine is no longer makin good power. . . If I were to mess with the timing it would be to take some out of the car...more timing normally adds more bottom end...you don't need that as much with the 4.10's
    2013 GT Premium Auto 3.15 gear
    Flowmasters
    JLT CAI
    American Racing Rims
    SCT Programmer with Bama tune
    12.33@110
    2002 Mustang GT --Sold
    You are not running out of top end with those 4.10's. With a 26" tall tire and a 98 mph trap speed your finish line rpm is in the neighborhood of 5,200 rpm in 4th (1:1)
    How many miles are on the car? The valves may be floating if the valve springs are tired.
    washington
    158
    Not running out of top end at all,just not making good power at higher rpm's."Its revving like a bitch just not moving"
    washington
    158
    The car only has 40,000 on it so i know its nothing major.
    Quote Originally Posted by 1994cobra View Post
    is the clutch slipping??? just a thought...
    What's the finish line rpm??
    washington
    158
    About 5,800
    washington
    158
    Was,nt slipping then,but it is a little now.Its time to replace the stock clutch soon anyways.Try to get it through the summer and then I am sure I will be giving you a call.KING COBRA CLUTCH????????
  1. Top ideas
    By thaley21 in forum General Tech
    Last Post: 03-16-2011, 10:51 AM
  2. any ideas?
    By 08stangftw in forum The Bar
    Last Post: 06-04-2010, 01:16 AM
  3. Ideas on a tune??
    By v6mustang01 in forum Fox-SN95
    Last Post: 06-01-2008, 06:15 PM
  4. Any Ideas?
    By 2001GTTT in forum S197
    Last Post: 04-13-2008, 10:58 AM
  5. any ideas
    By cc4x4rider in forum General Tech
    Last Post: 07-29-2007, 10:13 AM
