Results 1 to 3 of 3
Thread: Quick Teck Question - Speedo Gear
    Are speedo drive gears the same from AOD to T-5? Also are T-5 to Tremec the smame (this I belive to be true).
    I am trying to pick a gear for my Galaxie, and all the bags I have from Lou are saying AOD....Im not even sure why I would have more than 3 of these for I have only had 3 AOD 5.0 cars....lol
    Plum
    605
    Does this help?
    Manual Transmissions with 6 Tooth Drive Gear
    Not found in OEM applications
    Item Number
    N/A
    3.08 Gear Ratio / Not possible
    C0DZ-17271-A
    3.27 Gear Ratio / Maroon 16 Speedo Gear
    C3DZ-17271-C
    3.55 Gear Ratio / White 17 Speedo Gear
    C0DD-17271-B
    3.73 Gear Ratio / Yellow 18 Speedo Gear
    C0DZ-17271-B
    3.90 Gear Ratio / Pink 19 Speedo Gear
    C1DZ-17271-A
    4.10 Gear Ratio / Black 20 Speedo Gear
    C4OZ-17271-A
    4.30 Gear Ratio / Red 21 Speedo Gear
    Manual Transmissions with 7 Tooth Drive Gear
    1983-1989 T-5 OEM
    Pre 1993 T-5 Aftermarket
    1996-1998 Cobra T-45 OEM
    All Tremec Transmissions
    Item Number
    C0DZ-17271-A
    2.73 Gear Ratio / Maroon 16 Speedo Gear
    C0DD-17271-B
    3.08 Gear Ratio / Yellow 18 Speedo Gear
    C0DZ-17271-B
    3.27 Gear Ratio / Pink 19 Speedo Gear
    C1DZ-17271-A
    3.55 Gear Ratio / Black 20 Speedo Gear
    C4OZ-17271-A
    3.73 Gear Ratio / Red 21 Speedo Gear
    Jeep Part #j3167393
    4.10 Gear Ratio / White 23 Speedo Gear
    Manual Transmissions with 8 Tooth Drive Gear
    1990-1995 T-5 OEM
    1996-1998 T-45 OEM Except Cobra
    Item Number
    C0DD-17271-B
    2.73 Gear Ratio / Yellow 18 Speedo Gear
    C1DZ-17271-A
    3.08 Gear Ratio / Black 20 Speedo Gear
    C4OZ-17271-A
    3.27 Gear Ratio / Red 21 Speedo Gear
    Jeep Part #j3167393
    3.55 Gear Ratio / White 23 Speedo Gear
    Jeep Part #j3167393
    3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy. See 6 tooth table.)
    Jeep Part #j3167393
    4.10 Gear Ratio / White 23 Speedo Gear (Not 100% accurate. This combination will offer the best accuracy without changing the drive gear. Change drive gear to a 6 tooth for complete accuracy. See 6 tooth table.)
    Automatic Transmissions with 7 Tooth Drive Gear
    1983-1989 Automatic Transmissions
    Item Number
    D0AZ-17271-A
    2.73 Gear Ratio / Blue 16 Speedo Gear
    C7AZ-17271-B
    3.08 Gear Ratio / Gray 18 Speedo Gear
    C7VY-17271-A
    3.27 Gear Ratio / Tan 19 Speedo Gear
    C8SZ-17271-B
    3.55 Gear Ratio / Orange 20 Speedo Gear
    D0OZ-17271-B
    3.73 Gear Ratio / Purple 21 Speedo Gear
    Jeep Part #j3167393
    Automatic Transmissions with 8 Tooth Drive Gear
    1990-1998 Automatic Transmissions
    Item Number
    C7AZ-17271-B
    2.73 Gear Ratio / Gray 18 Speedo Gear
    C8SZ-17271-B
    3.08 Gear Ratio / Orange 20 Speedo Gear
    D0OZ-17271-B
    3.27 Gear Ratio / Purple 21 Speedo Gear
    Jeep Part #j3167393
    Jeep Part #j3167393
    3.73 Gear Ratio / White 23 Speedo Gear (Not 100% accurate.)
    Jeep Part #j3167393
    4.10 Gear Ratio / White 23 Speedo Gear (Not 100% accurate.)
    Now if you really want to change the internal drive gear of your manual tranny you can match it according to the table below. Be aware that the 6 tooth will offer the most combos for numerically higher gear ratios and offer the greatest degree of accuracy. The 6 tooth gear selection table for a manual tranny is the first in the page.
    Item Number
    E3ZZ-17285-B
    6 Tooth Internal Drive Gear / Black
    E3ZZ-17285-A
    7 Tooth Internal Drive Gear / Yellow
    F0ZZ-17285-A
    8 Tooth Internal Drive Gear / Green
    Thanks!
  1. 20 tooth speedo gear
    By Dan B. in forum Ford Parts
    Last Post: 06-15-2012, 10:03 AM
  2. Which speedo gear??
    Last Post: 04-16-2010, 11:32 PM
  3. speedo gear
    Last Post: 01-26-2009, 11:14 PM
  4. Speedo Gear?
    By Stangman701 in forum General Tech
    Last Post: 10-07-2008, 12:21 AM
  5. Speedo Gear
    By static-x in forum General Tech
    Last Post: 05-30-2007, 02:09 PM
