Results 1 to 3 of 3
Thread: Trac-loc rebuild questions.
    Bench-racer at best! Gearbanger99's Avatar
    9
    New guy here with some 8.8 questions. Is rebuilding a trac-loc (clutch plates) a DIY job? Would it be wise to raplace axle bearings while I'm in there?(96k) Gears aren't oe so the bearings may not be very old. Should I use carbon-friction discs or just buy a new and better diff? Any advice would be greatly apprectiated.
    Thanks, Steve
    yes i would replace the ring gear carrier bearings while your in there, and for a street car the kevlar or the stock replacements are great, ar you having troubles with one wheel spinning??
    9
    Mostly on the 1-2 upshift. On these warmer 70+ degree days we've had my summer compund tires are hooking better and can feel the diff let power slip more and more.
  1. Ford 8" Equal loc 3:00 gear.
    By map351 in forum Ford Vehicles
    Last Post: 05-15-2014, 10:10 AM
  2. OEM 8.8 28 spline trac-loc carrier
    Last Post: 05-05-2011, 02:05 PM
  3. Trac-lok help
    By 05mineralgt in forum General Tech
    Last Post: 11-13-2009, 10:34 AM
  4. 4.10 gear install & Trac-Lok rebuild
    By wicked400ex in forum Wolfpack Speed
    Last Post: 04-24-2009, 02:16 PM
  5. Changing Trac-Lok
    By LXguy88 in forum Fox-SN95
    Last Post: 09-15-2007, 10:32 AM
