Results 1 to 2 of 2
Thread: Forged Piston have enough meat?
    Yellow is faster!
    York PA
    273
    As the title says. Will I be able to remove enough material from the stock pistons to make the victor Jr. 2.05 and the 560 intake lift cam work? I have heard 2 opinions already one says yes another says no. Do I have to stay with the .080 clearance on the PTV.
    What do you think is the best way to check PTV clearance? I was planning on doing the lighter springs and feeler gauges does this sound like a plan? Can I do this without using a head gasket and just add the thickness of the headgasket?
    Thanks for your help in advance.
    Quote Originally Posted by 04yellowcobra View Post
    0.080 is the minimum, i like to see 0.100 for race application, and i have notched stock pistons for 2.02 valves but never 2.05.... The best way to check ptv is get some silly putty or play dough, clean the piston tops ( you want it to stick here), put some light grease or oil on the bottom of the valves, bolt down (no torque, with gasket) head, install proper pushrod and rocker, then adjust the rocker to your spec, then just turn the engine over 2 turns then take it apart and measure your silly putty, be sure and check the whole thing not just one spot as the valve may be canted slightly diff in the victor heads over the stock heads, but i know we had to notch the stock 87-92 pistons for 2.02 valves...
  1. Anyone for deer meat?
    By stieny in forum Pictures & Videos
    Last Post: 03-16-2009, 11:33 PM
  2. Want:deer Meat
    By INSANELY CRAZY in forum The Bar
    Last Post: 10-25-2008, 09:45 AM
  3. Meat flaps = stitches
    By Domination in forum Pictures & Videos
    Last Post: 10-23-2007, 09:29 PM
  4. Replies: 14
    Last Post: 05-05-2007, 09:53 AM
  5. What Piston???
    By Viper_ed in forum Fox-SN95
    Last Post: 03-16-2007, 11:57 AM
