Results 1 to 3 of 3
Thread: wheel hop after UCA/LCA install
    Morgantown WV.
    563
    I have recently installed CHE double adjustable uppers with sheprical bushings on the torque box side and new poly carrier bushings on the diff side. The lowers are CHE also but the are solids wilh poly/derlin bushings/bearings. I have also removed the quad shocks.
    I have not adjusted my pinion angle yet and just adjusted uppers to the lenght of the stock control arms. Would a bad pinion angle cause wheel hop? Because when I'm in the burnout box and try to do a burnout it's hopping on me.
    665/540 New times coming
    Mt Pleasant, PA
    4,905
    Deff. check the pinion angle. right around -3 sounds good with your setup.
    Morgantown WV.
    563
    will do
  1. Replies: 3
    Last Post: 08-24-2011, 10:58 AM
  2. Long Wheel Stud Install
    By NateSVT in forum General Tech
    Last Post: 07-12-2010, 02:31 PM
  3. LCA/UCA and Sub Frame connectors
    Last Post: 12-05-2008, 08:22 AM
  4. Looking for ideas on how-to hop up my '03 GT
    By redfire vert in forum S197
    Last Post: 12-04-2007, 12:30 PM
  5. No wheel hop on this comercial?
    By mikeymustang in forum Pictures & Videos
    Last Post: 10-15-2006, 12:17 PM
