Results 1 to 17 of 17
Thread: how fast without a cage?
    Oct 2007
    3,125
    I did a search on here and on PRP's site and couldn't come up with anything.
    Whats the fastest you can run without a cage at PRP?
    I've never taken any of my cars to the track before, so this is all new to me :o
    Also, how much better is the car going to hook at PRP than on a street? I assume much better? my car is making 520rwhp on a slightly optimistic dyno (amazon racing's dyno) and I'm running 305/35/18 nitto 555RII tires (just like the drag radial, but with stiffer side walls - I know that will hurt how the car hooks up). The car has supposedly gone 11.50 @ 127, but I think the previous owner might be embellishing the numbers a bit.
    Thanks in advance!
    Ligonier, PA
    6,365
    at a prp test n tune, you wont hook worth a s**t unless youve got some good drag radials/slicks. My car makes like 240 rwhp(being optimistic) and i spun like a mofo all the time there....not bashing PRP at all so spare me the drama....(you know who you are). Good luck man.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Oct 2007
    3,125
    shit.
    What about my question as far as the times go? although it sounds like I won't have to worry lol
    Ligonier, PA
    6,365
    dont hold me to it but i thought i remembered hearing that if you are under 12's then you gotta have a cage....or maybe its just a helmet...I know its one or the other....obviously my super monster car doesnt go under 12's.....or 13's.....or 14's....lol.
    1991 BMW 325iX
    1978 Ford F150
    You need a 6 pt roll bar with door bars when you run the following:
    Coupes: 11.49
    Verts: 13.99
    Robinson Twp.
    2,143
    That's the one good thing about PRP, they don't really care about that stuff too much. I've run 11's without even a helmet. I don't think you'll have anything to worry about.
    2015 Charger Hellcat
    85 GT
    73 F250
    Lifted, 35's, 460 4spd
    Real name = Ray
    Oct 2007
    3,125
    Quote Originally Posted by Killercanary View Post
    Coupes: 11.49
    Verts: 13.99
    I don't like the sound of that. There are so many factory cars that are verts that run under 14 seconds though, there is no way they can enforce that. There are a handful of stock cars that can run faster than 11.49 too. That sucks.
    I do like the sound of this however. How much trouble do you have putting the power down? Are you on DRs?
    Senior Member casper gt's Avatar
    Oct 2007
    creighton pa
    260
    cage
    just make shure to go up on tnt wed night etc. you should be ok. different story on race days -13.99 no helmet -11.99 no cage you wouln't make it back the return rd before they kick you out. call up there & leave message for Larry or Doug they will call you back & answer any questions you have.
    NHRA Requirements are here..........
    http://www.nhra.com/contacts/tech_faq.html
    The IHRA (PRP) is the same. As has been said, you are generaly okay until you put a dial in on the car.
    Bob Myers
    Oct 2007
    3,125
    Thanks guys, I really appreciate that NHRA link! So I should be safe for the T-n-T nights with no cage?
    JJsAutomotiveRacing.com SoLow's Avatar
    Jun 2007
    White Oak, PA
    957
    Quote Originally Posted by casper gt View Post
    its 11.50 or faster, not 11.99
    R.I.P Frankie
    Robinson Twp.
    2,143
    Quote Originally Posted by MBH View Post
    Only time I've ever been to the track with drag radials my stock clutch was shot. I've gone a best of 11.84 at 121 on my street tires. They're the crappy sumitomo's, but the IRS does pretty good at planting the power so I was still able to get a 1.94 60' I believe. I've done a little better on the 60' time with a different set of street tires. They were Avon M500's which I think are discontinued now, but I was able to get a 1.85 60' time with those. I would imagine with the Nittos you have you should expect 1.7's or 1.8's. I'm not sure how bad the stiffer side walls will hurt you. I'd say take them down to about 15 psi then come of the line fairly easy and you should be able to floor it about half way through 1st as long as the tires are still fairly warm and the track prep isn't too bad.
    85 GT
    73 F250
    Real name = Ray
    Built, Cammed, CCW'd SVT NateSVT's Avatar
    Monroeville
    856
    I ran 11s in my vert and I never even use a helmet. I have friends that run low 11s without a roll bar/cage and they don't say anything. They don't care.
    2004 SVT Cobra - sold
    2000 Yamaha R1
    2006 Yamaha R1 - Raven
    10.89 @ 127.6 1.61 60' with a ported Eaton
    Oct 2007
    3,125
    Quote Originally Posted by NateSVT View Post
    lol awesome. You get that thing dynotuned yet? your car pulls awfully hard in those videos!
    Thats a big relief with PRP though, I was going to axe any further power upgrades down the road if I couldn't even take the car to a track. I was wondering how so many people are able to get such good times and have no cage, I just figured that they ran the time and got the boot. Shows what I know!
    SFI SPECIFICATIONS
    Mandatory at ET (or quicker) Item SFI Spec
    13.99 Drive shaft loop (slicks)
    13.99 Helmet (Snell K98+)
    13.49 5-pt harness (convertible) 16.1
    13.49 Approved rollbar (convertible)
    13.49 (IHRA) Drive shaft loop (slicks)
    11.49 Drive shaft loop (street tires)
    11.49 Approved flywheel & clutch (manual transmission) 1.1, 1.2
    11.49 Approved protective jacket 3.2A/1
    11.49 Approved roll bar for all vehicles
    11.49 Approved 5-pt harness 16.1
    11.49 Approved flywheel shield (manual transmission) 6.1, 6.2
    11.49 (IHRA) Approved mounted fire extinguisher
    11.49 (IHRA) Approved flywheel shield (automatic transmission) 4.1
    10.99* Approved roll cage (convertible)
    10.99 Approved harmonic balancer 18.1
    10.99 Approved aftermarket axles
    10.99* Approved transmission shield (automatic transmission) 4.1
    10.99 (IHRA) Competition License* Class D
    9.99 Approved flexplate & shield (automatic transmission) 29.1, 30.1
    9.99 Approved roll cage & window net* 27.1
    9.99 Master cutoff switch
    9.99 Competition License Class 4, Cat. C
    9.99 Chassis Certification
    9.99 Approved jacket/pants/neck collar/gloves* 3.2A/5, 3.3, 3.3/1
    9.00 (IHRA) Roll cage & window net
    8.99 (IHRA) Competition License Class C
    8.49 On-board fire system
    8.49 to 7.50 Chassis certification 25.4/25.5 (3600#)
    7.99 (IHRA) Competition license Class B
    7.49 & quicker Chassis certification 25.1E (2800#)
    7.50 & slower Chassis certification 25.2 (3200#)
    7.49 Competition license Class 3, Cat. C
    IHRA Pro Stock Competition license Class A
    150mph + Parachute required
    200 mph + Head & Neck Restraint required
    * Also required for 135 MPH or faster
    Senior Member Jivepepper's Avatar
    Morgantown WV.
    563
    I have ran 11.3s there a few times before my roll bar on TnT's, no one says anything.
    665/540 New times coming
    Old times with 516/453 11.10 @129 Best trap 130.69 -750' DA lol
    DYNO VID ---> http://www.youtube.com/watch?v=K9uOS732mdA
    Castle Shannon
    1,276
    are Ttops considered an "open" vehicle ??
  1. Replies: 20
    Last Post: 06-10-2014, 08:07 AM
  2. Roll Cage
    By crazylou in forum General Tech
    Last Post: 11-19-2009, 07:45 AM
  3. autometer cage
    By George C in forum Ford Vehicles
    Last Post: 06-11-2007, 02:27 PM
