Results 1 to 5 of 5
Thread: valve guide seal removal
    3,316
    Is it just a matter of taking a pair of pliers, grabbing onto the lip that sticks up a little, and gently working it from all sides until it comes out?
    just want to make sure before I screw up a valve guide in the process.
    Thanks.
    so you mean valve seal?? the guides require a air hammer to get out..
    3,316
    not the valve guide, the valve guide seal.
    once you remove the valve spring below the valve spring is a metal disc and what appears to be a rubber seal below that. Im trying to sort out if that has to be removed before a head would go to cleaning. Trying to minimize what the machine shop has to do aside from cleaning, crack checking, and deck checking.
    this is a v6 head, btw if that helps.
    just take it all off, but remember if those are allum heads you will need to have those steel cups/plates under the springs again, the spring should never touch the allum head..
    3,316
    agreed.
    the question is, whats the best way. Pliers? special tool? by hand?
  1. Replies: 0
    Last Post: 07-14-2013, 12:46 PM
  2. Turbocharging - A Quick Guide
    By phillysrt4 in forum General Tech
    Last Post: 01-03-2010, 03:00 PM
  3. twin screw guys... help guide me
    By MBH in forum SN95-New Edge
    Last Post: 08-12-2008, 03:16 PM
  4. Survival guide for pooping
    By wick in forum The Bar
    Last Post: 03-11-2007, 12:48 PM
  5. Replies: 1
    Last Post: 11-11-2006, 02:15 PM
