Results 1 to 5 of 5
Thread: valve guide seal removal
    Dead Sea Racing Crew phillysrt4's Avatar
    3,316
    Is it just a matter of taking a pair of pliers, grabbing onto the lip that sticks up a little, and gently working it from all sides until it comes out?
    just want to make sure before I screw up a valve guide in the process.
    Thanks.
    so you mean valve seal?? the guides require a air hammer to get out..
    3,316
    Quote Originally Posted by Rodeheaver's View Post
    not the valve guide, the valve guide seal.
    once you remove the valve spring below the valve spring is a metal disc and what appears to be a rubber seal below that. Im trying to sort out if that has to be removed before a head would go to cleaning. Trying to minimize what the machine shop has to do aside from cleaning, crack checking, and deck checking.
    this is a v6 head, btw if that helps.
    just take it all off, but remember if those are allum heads you will need to have those steel cups/plates under the springs again, the spring should never touch the allum head..
    3,316
    agreed.
    the question is, whats the best way. Pliers? special tool? by hand?
  1. Replies: 0
    Last Post: 07-14-2013, 11:46 AM
  2. Turbocharging - A Quick Guide
    By phillysrt4 in forum General Tech
    Last Post: 01-03-2010, 02:00 PM
  3. twin screw guys... help guide me
    By MBH in forum SN95-New Edge
    Last Post: 08-12-2008, 02:16 PM
  4. Survival guide for pooping
    By wick in forum The Bar
    Last Post: 03-11-2007, 11:48 AM
  5. Replies: 1
    Last Post: 11-11-2006, 01:15 PM
