Results 1 to 13 of 13
Thread: car problem help!!!
    817
    car problem help!!!
    make a long story short i bought a stang with some mods that was missing a bit not firing on 2 3 and 5 cylinder so i tore it down it had a blown head gasket between 2 and 3 cylinder and number 5 had a burnt valve so i bought some h.0 heads off 393 rag they looked really good well i put it together all cylinders are good but number 5 is dead plug has no gas smell looks like new i put new plugs wires cap rotor button still number 5 is dead any suggestions? could it be a clogged injector it got 24# in it let me know what i should proceed with gettin ready to tear it back apart soon
    Check for spark, fuel, compression, if that cyl had a burnt valve before i would check for a wiped lope on the cam in that cyl... Or a vaccum leak on that cyl..
    Sounds like no fuel.
    817
    gonna pull injectors out here in a little bit any suggestions on how to clean em or if i can?
    817
    help
    i did a compression check on number 5 cylinder it got 150 lbs in the cylinder still dead!!!! any suggestions thanks alot
    PM returned...
    Put a noid light on the number 5 injector plug to make sure the injector is getting its pulse. I had a dead cylinder once caused by a bad connection between the wiring harness and the ECU.
    817
    bought a noid light set has no signal to injector any one have the whole injector harness i can jus change it out?
    You could try cleaning the Salt and Pepper connectors. I think I have an injector harness if that doesn't work.
    817
    runs awesome got it fixed wire was melted
    Told ya.
    Mt Pleasant
    2,916
    i said it was either the injector or in the the wiring. damn im good
    817
    yea u jus had a lucky guess
  1. c4 problem
    By badstanglx in forum General Tech
    Last Post: 05-19-2012, 11:35 PM
  2. Little problem
    By 383taman in forum Pictures & Videos
    Last Post: 08-20-2009, 12:22 AM
  3. Problem with 91 gt
    By jclose11 in forum The Bar
    Last Post: 07-23-2008, 09:29 AM
  4. 5.0 Problem
    By Black87GT in forum Fox-SN95
    Last Post: 06-03-2008, 11:39 AM
  5. problem with my car...hoping its just a clutch...
    By phillysrt4 in forum The Bar
    Last Post: 02-08-2008, 04:30 PM
