Results 1 to 20 of 22
Thread: Thermostat
Hybrid View
    Selinsgrove, PA
    526
    Thermostat
    well as some of you know i have asked before and still have no figured out why my car backfires/pops and bucks for the first like 5 minutes when first started, well i was just reading on the corral, that putting a 160* tstat in a 5.0 is not a good thing, because it will not be able to heat up properly,well i replaced the original thermostat with a 160* when i did the cobra intake install, could this be the reason why im having problems, and causing it to run like shit when first started!?
    Fox/n.
    i b where im at
    674
    changing the stat would not make a difference on how your car runs on the innital start up .. it will just make your car run cooler and thats always good .. so im told .. ive always ran a 160 in all my stangs and never had that prob
    out in the woods
    4,948
    i always ran 180* but my buddy ran the 160* and i cant recall him having any issues
    Selinsgrove, PA
    526
    well what i read said that during initial startup the car will not reach its operating temperature causing it to run very lean...
    Fox/n.
    I will first say that I'm not 100% up on the 5.0 EEC's like I am the 2.3 stuff, but in general.........
    Before the ECT reaches a certain point, the Ford strategies are to run off base tables, pretty rich, and fixed timing. In other words, the t'stat shouldnt make a difference on a cold start. If you had a wideband, you would see it that way.
    Now if, you was asking why your milage sucks and the car doesent run like it should once "warmed" up................
    Selinsgrove, PA
    526
    so basically its the exact opposite of what my car is doing so let the tstat alone? lol because my car runs like shit cold, but good when warm, and what you just described it should run good when cold, but shitty when warm??
    lol
    Fox/n.
    Stangman Stangman's Avatar
    North Hills
    234
    I had 3 fox bodies over the years. All 3 were 160 degree stats. No issues.
    2013 GT Premium Auto 3.15 gear
    Flowmasters
    JLT CAI
    American Racing Rims
    SCT Programmer with Bama tune
    12.33@110
    2002 Mustang GT --Sold
    Oct 2007
    creighton pa
    260
    thermostat
    should be A'OK with 160 in a 5.0 (4.6 another story) most likely another problem elsewhere
    1,220
    Sounds like the coil breaking down or some other ignition problem, especially with all this rotton wet weather. Could be fuel too though. Has anyone tried to scope the engine when its acting up.
    State College, PA
    3,552
    is it the stock fuel pump? if so ditch that its probably gettin tired
    2013 Mustang GT
    1999 Contour SVT
    1,220
    Does the car have mass air? Could be a connection problem somewhere also and when the car gets hot it starts making good contact. I would check the coolant sensor as well as the air charge temp sensor. I have seen air charge sensors get a piece of carbon on them and the car runs like crap. That problem should be hot also though. Try to look at the grounds and make sure they are clean and tight. Does the car have any mods?
    Selinsgrove, PA
    526
    i was kinda thinkin fuel filter??, ill replace that tomorrow, because im also getting horrible gas mileage, like 9mpg city..
    Fox/n.
    Selinsgrove, PA
    526
    yes, mods are: bbk long tubes, bbk hpipe, flowmaster 40s, stage 3 clutch/flywheel, u/d pullies, cobra upper/lower intake manifold, 65mm tb, 3.73 gears, and a pro 5.0 shifter..
    Fox/n.
    What is your timing set to? Could be the coolant temp sensor also.
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    i posted on another site already about your problem but ill post it again your pump is taking a shit and needs to be replaced i had the same problem with my 88 initial start up and until the pump got warmed up it would do the same thing your car is doin
    Selinsgrove, PA
    526
    Shit, and your sure its the pump? i really dont want to have to do that....and i dont want it to be like everything else, replace it, and still have the problem..
    Add:
    Well i just put the fuel filter in, and checked for vacuum leaks by spraying starter fluid on all the vacuum lines with the motor running, and nothing happened, so i guess there is no vacuum leaks? but it still idles really rough and still bucks and pops...
    Could it b the tps still!?!?
    Fox/n.
    Chandler, AZ
    1,532
    fuel pump ;)
    Senior Member TJH64's Avatar
    Delmont PA
    320
    Have you checked the fuel pressure?? I would suggest checking pressure at initial start up, see if fluctuation and/or low pressure is present. Let the car reach operating temp, or whenever it seems OK, then check pressure again. Compare the results. If there are discrepencies, as fastfox91 stated, the fuel pump would be suspect.
    Selinsgrove, PA
    526
    how can i check fuel pressure at the schrader(sp?) valve?
    Fox/n.
    Delmont PA
    320
    Quote Originally Posted by Black87GT View Post
    Take the cap off of the valve, attach a pressure gauge by threading the fitting onto the valve. Pressure should read between 37 and 40 PSI.
    Always use caution when working with a pressurized fuel system
  1. Thermostat question..
    By Hawkeye in forum Fox-SN95
    Last Post: 09-26-2009, 02:32 PM
  2. Thermostat?
    By Shadowstealth in forum SN95-New Edge
    Last Post: 08-29-2009, 08:22 AM
  3. WTB Fox thermostat housing
    By Silverhatch in forum Ford Parts
    Last Post: 09-23-2008, 08:49 PM
  4. SVO/Turbo 4 thermostat housing bolts
    By mlowry1260 in forum Fox-SN95
    Last Post: 08-05-2007, 11:11 PM
  5. wtb thermostat housing
    By scott5 in forum Ford Parts
    Last Post: 04-28-2007, 09:13 PM
