Results 1 to 6 of 6
Thread: Need advice with 1995 Mach audio
    Gibsonia, PA
    323
    Hi.
    Can anyone give me some recommendations on replacing my 1995 GT convertible's Mach audio system?
    I have the two separate units - the stereo/cassette and the separate CD player lower down in the dash.
    I am just looking to upgrade to stereo/cd and speakers. No subs or anything like that. Would like to use the bottom area where the separate cd player is for storage or something else.
    Does the Mach audio include any small amplifiers somewhere up in the dash? What exactly can and should I replace? Can the speakers be easily replaced? Any recommended places to get the stuff?
    I would appreciate the advice of anyone who has done this before.
    Thanks.
    Oct 2007
    creighton pa
    260
    radio
    very simple need aftermarket head unit & ford premium sound wiring harness kit. wire the plug into new head unit(make shure to connect blue/white wire on both sides that will turn your fact. amp on) you should be fine with fact. speakers. then just see Lou & get fact. cd delete (plastic tray) & your done. I see your from gibsonia I'm right off 910 & rich hill rd. & mines done just like I said,you can stop by & have a look if you want before you start.
    Oct 2007
    creighton pa
    260
    radio
    oh yea 94-2000 are all the same.
    Gibsonia, PA
    323
    Thanks a bunch. Sounds like it is pretty straight forward. I may take you up on that... I would like to see how yours looks. I will send you a PM when I get close to doing it.
    Oct 2007
    creighton pa
    260
    no problem,let me know.
    Gibsonia, PA
    323
    Larry, thanks for the help. I got everything installed and working. It looks much cleaner now and now I have a little extra storage space in the car ;)
    Thanks!! Vince.
  1. Replies: 0
    Last Post: 08-31-2012, 11:10 PM
  2. Replies: 16
    Last Post: 03-13-2012, 09:21 PM
  3. Mach 1000 audio system
    By White5.0 in forum Ford Vehicles
    Last Post: 08-11-2010, 07:32 PM
  4. Audio Help
    Last Post: 12-11-2008, 09:08 PM
  5. Car Audio
    By coralcoupe1993 in forum For Sale
    Last Post: 09-30-2007, 01:20 PM
