Results 1 to 5 of 5
Thread: Pulled Codes..
    Selinsgrove, PA
    526
    Pulled Codes..
    Ok well i went out an bought a code reader, and pulled the codes this morning, this is what i came up with (got the codes 2 times tho??)
    i got:
    with a KOEO (Key On Engine Off) test
    code 34: EGR Valve Position(EVP) sensor or pressure feedback EGR (PFE) sensor: signal voltage out of self-test specification limits, or signal voltage above closed limit during normal engine run operation or, signal indicates insufficient EGR flow.
    and with a KOEO (Key On Engine On) test
    code 42: Exhaust Gas Oxygen (EGO) sensor: voltage signal always "rich"(high value) - does not switch
    then i also got two code 11: System pass with the Key On Engine Off test
    So what do i need to do? no idea really what any of this means???
    Fox/n.
    Selinsgrove, PA
    526
    ok just erased the computer, and now im only getting code 11 with the key on engine off test, so i guess it was reading the old problem with the EGR, so all is good now...
    now i should just replace the oxygen sensors??
    Fox/n.
    3,316
    if you get eh o2 sensor code again, i would.
    Selinsgrove, PA
    526
    yes i am still getting the o2 sensor code, im in the process of removing them, little bitches are tight as hell.. lol
    Fox/n.
    3,316
    they are a pain in the ass thats for sure
    and they're the kind of thing where you want to take your time and put anti-seize on your replacement
  1. trouble codes
    Last Post: 08-09-2012, 02:15 AM
  2. help with trouble codes 94 gt
    By 94gt5.0 in forum Fox-SN95
    Last Post: 05-25-2011, 09:49 PM
  3. Pulled More Codes.
    Last Post: 09-11-2008, 07:20 PM
  4. More Codes..
    Last Post: 05-29-2008, 04:45 PM
  5. Codes
    Last Post: 05-28-2008, 09:22 PM
