Results 1 to 6 of 6
Thread: Harmonic Balancer Question
    Senior Member TJH64's Avatar
    Delmont PA
    320
    I installed a new Professional Products SFI certified damper on my 347 yesterday. In order to use the Summit underdive crank pulley, I will need to get a spacer to align with the other accessory pulleys. Have anybody with a 94/95 utilized a spacer and know what size is required??
    Delmont PA
    320
    blizzard, thanks for posting that link. The spacer shown is what I will need, however, there are various thicknesses available, and that is what I'm trying to determine, what will work on the bastard 94/95 with their unique accessory locations.
    Mt Pleasant, PA
    4,905
    Give me a call tomorrow at the shop, I should have the correct one there.
    Delmont PA
    320
    Lou' I'll call you tomorrow!!
    TJ
    i b where im at
    674
    393 rag HAS A SPACER FOR SALE CHEAP . check him out on here
  1. Romac 6-rib harmonic balancer - 96+ 4.6 liter GT/Cobra
    Last Post: 06-27-2010, 12:58 AM
  2. Replies: 8
    Last Post: 01-19-2009, 12:59 AM
  3. 2.5 Harmonic Balancer
    By map351 in forum Ford Parts
    Last Post: 09-09-2008, 03:35 PM
  4. what oz flywheel and balancer is factory
    By stangfever in forum Ford Parts
    Last Post: 03-30-2008, 11:41 PM
  5. balancer question
    By Milewsky80 in forum Fox-SN95
    Last Post: 07-29-2007, 04:35 PM
