Results 1 to 3 of 3
Thread: 99-04 parts needed
    ruffsdale
    3,625
    99-04 parts needed
    I need headlight wiring harness,rotors all the way around,and the brake lines from the abs box to the right wheel well that goes to rear brakes, trying to cut some corners save some cash on parts so i can have it together for carlise, hit me a PM or call 724-875-0984.
    Senior Member TJH64's Avatar
    Delmont PA
    320
    Call Scott @ 724-423-8874. He lives in Norvelt and has all the parts you need. Tell him TJ gave you his #
    NEWB
    167
    i have stock rotors off my 01 GT
    PM me an offer
    2001 Black Gt 5spd
    Kenne Bell is my BOY
  1. Parts needed
    By lawrence2012 in forum Ford Vehicles
    Last Post: 06-22-2012, 11:07 AM
  2. 99-04 parts needed
    By fast4ord in forum Ford Parts
    Last Post: 09-11-2011, 08:44 PM
  3. Parts needed
    By 383taman in forum Ford Parts
    Last Post: 04-20-2009, 08:56 PM
  4. parts needed 5.0
    Last Post: 03-19-2009, 09:29 PM
  5. who needed AC parts 87-93 ?
    By Shaggy in forum The Bar
    Last Post: 08-24-2006, 12:09 AM
