wat size tires should I get for a set of 18x9 18x10?
any recomendations?
i say fronts 275/40/18 and the rears 315/35/18
2018 Jeep Grand Cherokee
1931 Ford Model A - Project
1991 BMW 325iX
1978 Ford F150
1952 Ford F2 - Project
better make that 275/35/18 front and 315/30/18.
you're gaining an inch of wheel, so you have to reduce the sidewall to get close to the proper total wheel/tire height.
I hate giving this lesson. 1 inch = aprox 25.4mm. 17" wheel x 25.4 = 431.8
The second number on your tire is the percentage of tread width that your sidewall is in height. for example 245/45/17 tire or 275/40/17 or 315/35/17
245 x 45% = 110.25mm / 275 x 40% = 110mm / 315 x 35% = 110.25mm
So take 431.8 (height of 17" wheel in mm) + 220.5 (110.25+110.25 because you have to add sidewall for top and bottom) and you get approx 652mm total wheel/tire height.
So, take an 18" wheel (18" x 25.4 = approx 457). Take the aforementioned total wheel/tire height of the 17" package of 652 and subract the new wheel size of 457 = 195mm. This is the total tire sidewall you can have. Divide by 2 for top and bottom and you get 97.5.
You have to find/use a tire that calculates to 97.5mm on the sidewall to keep your stock wheel/tire height.
So 275 x 35 = 96.25 and 315 x 30 = 94.5
That's about as close as you're going to get. You can mess around with combos for 265/35 (92.75) and/or 305/30 (91.5) or anything else you can imagine.
2019 Colorado ZR2
Exactly! That is the combo that I run for street use.
Here are links to a couple tire size calculators:
http://www.miata.net/garage/tirecalc.html
http://www.1010tires.com/TireSizeCalculator.asp
http://ejelta.com/tiresize/index.html
Mark
LeMans Blue Z06
These would save you some money on the fronts :)
http://www.steelcitystangs.com/forum...ead.php?t=8042
I'd recommend 305/35/18 Nitto DRs if you're making decent power and want to run on a DR.
:o oops.....sorry.
1991 BMW 325iX
1978 Ford F150
