I need an exhaust for my 04 GT asap. I got 200 bux cash. I was suppose to buy one off someone else, but its no longer for sale..Anyone got anything?
2007 Civic SI fo do.
i-VTEC...Do you?
Josh
what do you need? a cat back??
so a he needs a cat back, litterally, not an Hpipe back.
Yeah, I need a cat back.
i-VTEC...Do you?
Josh
Is this the one you were trying to buy?? Just curious
http://www.steelcitystangs.com/forum...ght=exhaust+fs
02 MG GT
98 SVT Contour SF/MNB #2059
93 Civic Hatch
heres something u may want to check out. Not sure if it will help you or not.
http://pittsburgh.craigslist.org/pts/677250994.html
02 MG GT
93 Civic Hatch
thats not a bad deal..
So I should prob try and get that?
i-VTEC...Do you?
Josh
I'm a big fan of pypes products. I know that the violator mufflers sound pretty good.
02 MG GT
93 Civic Hatch
they sound good on this "piss yellow princess"............sorry Clark..LOL
http://youtube.com/watch?v=rumeapCBsEw
If you didn't hack your stock cat-back all to bits, you could probably buy 2 brand new Flowmaster or Magnaflow mufflers and have somebody weld them in ALL FOR JUST UNDER $200.![]()
2019 Colorado ZR2
Haha, I agree ^^ Oh well :) Anyways, Talked to the guy about the PYPES setup..Its still on his car and wont take it off til his new setup is ordered...I need something now lol
i-VTEC...Do you?
Josh
Im half tempted to just bolt the stock mufflers back on until I find something so it doesnt run like shit
i-VTEC...Do you?
Josh
If I go to a muffler shop and have them put straight pipes on after the cats will that give me the back pressure Im losing due to no exhaust?
i-VTEC...Do you?
Josh
Just and idea here and I might be way off on this... somebody correct me if I'm wrong.
I don't think your problem is a lack of back pressure. If you totally removed the cat-back section of your exhaust, then your rear O2 sensors are hella close to the end of your custom exhaust. The front O2 sensors check the exhaust before the cats and the rears check it after the cats to make sure they're doing something. Your rears might be getting a big whiff of fresh air and thinking your cats are cleaning up your exhaust WAY too much creating a lean condition.
Then, the computer would probably pull lots of timing and add lots of fuel. You said it falls flat at 4,500. Does it smell like it's running really rich and is it using obscene amounts of fuel?
Bolt the stock pieces back on there if you can and see if this clears your problem up.
You'll have to disconnect your negative battery cable or run your car through 3 driving-cycles to reset the computer.![]()
2019 Colorado ZR2
