Results 1 to 20 of 21
Thread: o2 Sensors.
    Almost Done Black87GT's Avatar
    Selinsgrove, PA
    526
    o2 Sensors.
    ok well i was going to replace my o2 sensors today and have run into quite the dilema, well when i crawled under the car with a 7/8 wrench to take the left side off (on my header) i saw that it was pretty much well rounded off, so i was like oh shit, so i went an bought a oxygen sensor take off tool thing from advance auto parts, thinkin maybe it would get a better grip, well no luck it just basically spins on the nut on the actual oxygen sensor, so idk what to do? other side looks fine, but this side is pretty much rounded off..
    What should i do?
    Fox/n.
    1. wild animal : a carnivorous animal of the dog family that has a sturdy square body, large cubic inches, a wide RPM range , and comes in many colors. Foxes are found throughout most of the world and hunt alone, mainly at night, relying on cunning and an acute sense of power and acceleration. They feed on mostly small rodents like rats(BBC) , mice (SBC) and snakes(Cobras).
    If they are right in your headers you should try a big pair of vise grips..or a big pair of channel locks.
    Senior Member Hawkeye's Avatar
    Mar 2008
    Plum
    605
    Quote Originally Posted by Rodeheaver's View Post
    X2
    "There's no substitution for cubic inches."
    93 GT, 408
    Best ET 10.93, 1.63 60ft, 121MPH
    All Motor.
    Senior Member blizzard's Avatar
    Mar 2008
    Castle Shannon
    1,276
    and some heat... and some blaster... and some heat. soak it with blaster, drive it around get it hot and cook it all off then soak it again. then try, probably gonna be a bitch.
    member 65 Fastback's Avatar
    Nov 2007
    South Hills
    303
    I found this excerpt, you might want to try it!
    Recently I rounded off the head of a tube nut. Tried various ways of
    >removing it, none worked.
    >I found a tool that works great at removing rounded heads. Vice-Grip
    >wrench: Not vice-grip pliers. This tool has 3 sided jaws that tightly
    >grip on the remaining sides of a rounded nut. It grips so tight that
    >even when pulling very hard it did not slip. The nut came off. Has the
    >advantage of being usable on tubing nuts where box end wrenches cant be
    Selinsgrove, PA
    526
    tried vice grips and channel locks and cant get it to budge, i guess ill try again tomorrow... damn things..
    Fox/n.
    Everything I have is slow 2001GTTT's Avatar
    Ligonier, PA
    6,365
    maybe just pound a socket onto it? whats how i got my stripped-out wheels locks off today..lol.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    2001 Mustang GT - gone but never forgotten. RIP.
    Right Wing Nut Dragger Troll's Avatar
    5,822
    edit:
    Last edited by Troll; 05-21-2008 at 11:56 PM. Reason: real ideas aren't good enough for Mr. Perfect
    2019 Colorado ZR2
    Ligonier, PA
    6,365
    Quote Originally Posted by Troll View Post
    yes... 3/4" socket. that's an awesome feeling when it starts to turn and you realize that it's NOT turning on the lock and actually working.
    12-point. anything else just slips.
    1991 BMW 325iX
    1978 Ford F150
    Nov 2007
    South Hills
    303
    Quote Originally Posted by Black87GT View Post
    It's a 3 sided Vice Grip wrench and not just vise grips.
    Polar Vortex
    6,031
    Pb blaster let it soak, Like said before sqeeze the sh!t out of those vise grips, thats really your only option unless you take your h or x pipe off
    Selinsgrove, PA
    526
    Quote Originally Posted by John4cam View Post
    on the headers... lol
    Fox/n.
    5,822
    dude, he's trying to help you and you're mocking him.
    how about "thanks" instead.
    2019 Colorado ZR2
    Ligonier, PA
    6,365
    F**K it.....cut em out...lol.
    1991 BMW 325iX
    1978 Ford F150
    Polar Vortex
    6,031
    Well you never really said what your exhaust was. Figured you just had shortys with off road x or h. Good luck!!
    Selinsgrove, PA
    526
    well i just got the one off i couldnt yesterday, with a torch and vice grips, and then i went to the other side and i cant even get it to budge, with torch, or running around in the car for 10-15 min to heat it up, and this one is completely round now... no room to use a pipe wrench, and no matter how tight i get them vice grips just seem to slip now???
    Just sprayed pb blaster on it, should i let it soak overnight and try again tomorrow, or should i go back out an try tonight??
    Fox/n.
    Ligonier, PA
    6,365
    just sprayed pb blaster on it, should i let it soak overnight and try again tomorrow, or should i go back out an try tonight??[/quote]
    I would keep spraying it, try it tonite, and if not really soak it and let it sit till morning.
    1991 BMW 325iX
    1978 Ford F150
    Mar 2008
    Castle Shannon
    1,276
    well it really wouldn't be that hard to take out anyway if you had to... but if you can (with the limited room) you can try to use a side grinder to flatten two opposite sides down... or even just get some good flat spots around it and go with the vice grips and torch again. and yeah, keep soaking around the threads withblaster... good luck...
    Selinsgrove, PA
    526
    well i just broke the damn thing off, and hammered a 13/16 socket on it to try an get it off, thought it was working at first, but its just rounding it off again..
    im lost idk what to do anymore..
    Fox/n.
    Ligonier, PA
    6,365
    is it a 12 point socket?
    1991 BMW 325iX
    1978 Ford F150
  1. o2 sensors?
    By Jivepepper in forum General Tech
    Last Post: 12-24-2009, 08:16 PM
  2. 2 New o2 sensors of a 2004 GT
    By 2001GTTT in forum Ford Vehicles
    Last Post: 12-24-2008, 06:10 PM
  3. O2 sensors...which ones do i buy???
    By White5.0 in forum Fox-SN95
    Last Post: 09-29-2008, 10:44 AM
  4. F/S o2 sensors
    By Jper in forum For Sale
    Last Post: 08-23-2008, 03:14 PM
  5. o2 sensors
    By Mitternacht in forum The Bar
    Last Post: 11-28-2007, 01:47 PM
