Results 1 to 14 of 14
Thread: engine opinions
    F'in Catalina Yacht Mixer 94svtcobra's Avatar
    In a Time Machine
    3,361
    engine opinions
    I lookin to possibly do an engine swap and was wondering what kind of setup you all could suggest. it's goin in my 94 cobra. I was thinking a 302 stroked out to a 347 with a kenne bell. any transmission or rear end issues with producing that much power??? I have the t5 tranny stock and stock rear end.
    Polar Vortex
    6,031
    Quote Originally Posted by 94svtcobra View Post
    With the blower I think a 331 stroker would be more reliable, and make good power. As for the drivetrain, it all depends on what your gonna use the car for. If you wanna bolt on some slicks at the dragstrip your gonna break something. If you want to cruise on some drag radials and get on it here and there you should be fine, JMO.
    In a Time Machine
    3,361
    it's goin to be a street car, drag radials. anything I should do to prep it for a small nitrous spray maybe a 50 shot of dry?
    Polar Vortex
    6,031
    Spray w/boost?
    In a Time Machine
    3,361
    yes.
    Polar Vortex
    6,031
    You will have to go with forged internals w/ or without the spray for it to last, I'm sure one of the shops here on this site could build you something reasonable, if not I know someone who is a certified ford tech who does work on mustangs on the side, very reasonable.
    In a Time Machine
    3,361
    any of the shops on here have a general idea on how much a 302 with a 331 stroker kit forged internals engine prepped for spray with a kenne bell sc would be???
    Big Daddy gmkillr's Avatar
    At the racetrack
    4,193
    Quote Originally Posted by John4cam View Post
    Why would the 331 be more reliable?
    What would it be more reliable than?
    Corvette Z06
    Growing up.............Not everyone does it!
    Senior Member TJH64's Avatar
    Delmont PA
    320
    There are two reasons to build a 331 vs a 347. One, if you are class racing and have cubic inch limitations, and secondly, if you just want to build an engine with less power. The choice is pretty obvious.
    Fordstrokers 347 4.030 bore, 3.400 stroke, 5.315 rod, 10.6:1CR
    Canfield 195 heads, Ferrea 6000 valves, Comp springs, Ti retainers, roller rockers, hand bowl blended
    Camshaft Innovations custom billet core hydraulic roller camshaft
    TFS Track Heat, 75mm TB, 90mm MAF, 36lb/hr inj
    TREMEC 3550, billet flywheel, RAM clutch, 4.10 gears
    Spoon Killer HidalgoGT's Avatar
    Uniontown
    1,792
    If your going 347 I would suggest an aftermarket block. 347 + kenne bell and spray would definetly test the lvl of strength on that stock block. Be a waste to see it split in half after all that money. As for the rest of the drivetrain. Don't think that stock T-5 would hold up very long with that much torque being thrown at it. Rear wise get some axles and a rear dif cover and it should be good.
    2001 Dodge 2500 The Big Bad "D"
    4" exhaust,38"MTZ's,5.5 Fabtech Lift,Cold air intake,Silencer ring MIA,Smarty tuner,Edge Drag comp, 64/71/.80 s300 turbo 175hp injectors.
    321Hp/783Tq New power numbers this spring.
    1987 Dodge 1/2 ton gasser 4x4 "jr"
    Ricers: For those who don't have the balls or skills to drive American Muscle.
    Not cool cause I don't drive a mustang anymore.
    Got Smoke?
    http://www.youtube.com/watch?v=BGIvJflAxZU
    North Hills of Pittsburgh
    430
    It all depends on what you want - NA or forced induction or Nitrous. I went the NA route with my 347 since I only wanted a car in the 12's and didn't want to split the block or buy a forged crank. You can build a 347 with a cast crank that makes 380 rwhp fairly easily and inexpensively. Once you go to forced induction, you should go with an aftermarket block and forged crank, which means more money. I'm sure others may disagree - JMO. I have read the KenneBell's generate a lot of heat - you should check into that and decide your use for the car. No matter which way you go you should set aside $300 for a custom tune after the build. Our 94 computers are not very forgiving.
    2016 GT Premium
    At the racetrack
    4,193
    Quote Originally Posted by TJH64 View Post
    X2, and how many classes have the c.i. limited to 331?
    Do you want to make less power?
    Corvette Z06
    In a Time Machine
    3,361
    no, I was tryin to produce around 450 mark maybe a lil more
    At the racetrack
    4,193
    450 rwhp
    347 c.i. stroker shortblock
    TEA 205 T.W. CNC heads
    Ported Holley Intake
    Custom cam
    42lb. injectors
    A custom cam guy can set you up to reach this goal. Jay at www.CamshaftInnovations.com is a great guy to deal with.
    Corvette Z06
  1. your opinions on engine (stroker) plans....
    By stangr6man in forum Fox-SN95
    Last Post: 11-19-2010, 08:00 AM
  2. WTB: Engine Stand + Engine Hoist
    By Black87GT in forum Ford Parts
    Last Post: 10-16-2008, 01:22 PM
  3. 5.0 engine shroud, battery tray, engine stand
    By madmaxin22 in forum Ford Vehicles
    Last Post: 08-24-2008, 06:54 PM
  4. Hypothetical engine build--opinions wanted
    By Pure Stock in forum Fox-SN95
    Last Post: 05-12-2007, 07:21 PM
