Results 1 to 8 of 8
Thread: Mass Air Voltage Too High
Hybrid View
    I was driving down the road the other day and my car just started dumping out black smoke and lost all power. After a day of troubleshooting, I found that my MAF voltage is 2.74 volts at idle. I have tested my MAF voltage in the past to troubleshoot a different issue, and at idle, voltage was .87. I also tested this on a buddys car, and at idle, his MAF voltage was under 1 volt.
    Right away I thought the MAF was bad. I borrowed a buddys meter, it did the exact same thing. I put my meter on his car and it produced .8 volts at idle as it should.
    I tested to make sure that I was getting 12 volts at the power going in to the meter as well.
    Does anyone know what could cause this? Bad ground maybe somewhere?
    I also tried 2 computers.
    The car is an 89 GT
    3,356
    Injector stuck open or bad O2 sensor maybe?
    Mark
    LeMans Blue Z06
    I should add that the car will run ok with the MAF unplugged, but that 2.7 volts at idle is telling the computer that there is significant air flowing into the engine and is dumping fuel to compinsate.
    Does the voltage change when you raise the rpm? or does it stay at that voltage?
    2011 Mustang GT Kona blue
    2002 F-150 FX4 true blue, with Lightning blower swap
    2004 F-150 FX4 forged bottom end, built trans, Street Lethal Performance 76mm turbo kit, Black, Gray Leather, 6"susp, 3"body on 37's
    Let us know your parts needs we will work to beat any price!
    (724)964-8419
    9am-5pm M-F
    In house chassis dyno
    It does go up as you raise rpm
    Well I found the problem. The bypass valve was leaking, so the blower was pulling air through the meter and pushing it out of the discharge tube where the bypass valve connects.
    3,356
    Good deal. Glad you fixed it!
    Mark
    LeMans Blue Z06
    Huntingdon PA
    1,136
    good find.
    709RWHP/750RWTQ
  1. wtb 24lb mass air meter and cold air intake
    By chuck94 in forum Ford Parts
    Last Post: 02-13-2014, 08:12 PM
  2. High Voltage issue on constant... car off. 90 fox
    By OctaneGraphix in forum Fox-SN95
    Last Post: 01-22-2014, 08:05 PM
  3. Replies: 1
    Last Post: 04-16-2013, 08:59 AM
  4. FS: 89 Mass Air Harness and A9L Mass air computer
    Last Post: 01-07-2012, 07:54 PM
  5. fox mass air vs sn95 5.0 mass air?
    By scott5 in forum Fox-SN95
    Last Post: 07-13-2007, 10:19 PM
