View Poll Results: What should I do with my split port heads? (read post before voting)
Voters
21. You may not vote on this poll
  • Clean em up and slap em on. They'll probably be fine.
    1 4.76%
  • Put em on, but get em checked before you boost.
    1 4.76%
  • Get em checked out before putting them on the first time.
    19 90.48%
Results 1 to 9 of 9
Thread: (read before voting) salvage yard heads - what should I do?
    3,316
    I picked up some aluminum v6 split port heads from a salvage yard along with the upper and lower intake. They seemed in pretty good shape (only 98k miles on it) and I suspect a bottom end engine failure (no indication of blown gaskets nor accident damage.
    The heads seemed in pretty good shape- only a minor amount of sludge in them that seems to be easily cleaned, and a minor bit of corrosion at the valve seals that I know will come off with some ATF fluid (its just surface rust on 2 valve seats). THe rockers, springs, and valves appear to be in good shape except for one which was a little tight coming out but may have been due to deposits as opposed to bent valves (havent cleaned anything yet).
    So I guess my question is this: Since the first phase of my project car is just to get it up and running in normally aspirated mode powered by megasquirt, am I ok giving it a thorough cleaning by hand, get a new set of rods (and possibly lifters) and do the swap now while the car is still being assembled electronically, or should I do "the 9 yards" and get them cleaned, beaded, crack checked, etc before putting them on.
    the car will have some downtime involved when the turbos go on which means if I wanted to have them checked and upgraded at that point there would be time to do so. The cost of a gasket set to me is not a major expense so Id be willing to do it that way if people think the heads as-is might be okay to use.
    When i took them off, I untorqued "out to in" to try and minimize warping of the head, going in a spiral pattern around the head removing bolts.
    Vote and comment.
    Thanks for the input.
    Somerset Co.
    2,907
    Getting any head checked is money and time well spent.
    3,316
    wow you ninja'd before the poll was done lol!
    Somerset Co.
    2,907
    I was looking for it...
    1,164
    i would have them checked to be 100% safe.
    with buying used mechanical stuff, you always run the chance of something happening.
    Uniontown
    1,792
    I agree checked would take care of any problems or guess work once they are on and you begin the tuneing.
    Got Smoke?
    3,316
    well with a resounding 12-1 vote so far looks like I'm going to get it up and running in singleport mode, then swap to split port for the tuning part.
    Castle Shannon
    1,276
    i just voted for the other to be different
    3,316
    lol!!
  1. Salvage Gt500
    By OCRnotch in forum The Bar
    Last Post: 04-04-2011, 05:01 PM
  2. mustang salvage yard in ligoneer??
    By Inkdcountryboy in forum The Bar
    Last Post: 04-28-2009, 04:36 PM
  3. What is a salvage title?
    By DRRummel in forum The Bar
    Last Post: 08-27-2008, 05:38 PM
  4. Need Local Salvage Yard Info
    By PaxtonShelby in forum General Tech
    Last Post: 08-05-2008, 08:10 PM
  5. Salvage old Lightning
    Last Post: 03-24-2007, 12:51 AM
