Results 1 to 2 of 2
Thread: Almost NEW Comp Cams Pro-Magnum 1.6 rockers
    LIKE NEW! Under 500 miles on these:
    Competition Cams Pro-Magnum roller rocker arms.
    * Made from 8650 chromoly steel
    * Has less weight (5%) at the valve than most aluminum rockers. This means more RPM and valve train stability.
    * Larger trunion with more needle bearings that spreads the load more evenly promoting longer life.
    * 1.6 rocker ratio
    * Stud mount
    * Fits 3/8 stud
    Summit sells these for $259.88 new.
    $160.00
    I'd be all over these Joe if I wasn't going with shaft rockers.
    TTT for you!
  1. Comp 270 cams
    By scott5 in forum SN95-New Edge
    Last Post: 05-15-2013, 09:11 PM
  2. 2v 4.6 5.4 comp cams
    By pinkpony20000 in forum Ford Vehicles
    Last Post: 05-12-2012, 09:01 AM
  3. f/s Comp Cams Pro Magnum Rockers
    Last Post: 03-29-2012, 10:40 AM
  4. comp pro magnum rockers
    Last Post: 04-02-2011, 11:25 PM
  5. sbf 1.6 magnum rockers
    By urgonnaluz2me in forum Ford Vehicles
    Last Post: 07-09-2008, 10:47 AM
