Results 1 to 3 of 3
Thread: ABS light came on today.
    Ligonier, PA
    6,365
    Any suggestions guys? no fluid on the ground or leaking, no hard braking or anything....it was off when i shut the car off and an hour later when i started it up, it was on.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    5,822
    Quote Originally Posted by 2001GTTT View Post
    yours has traction control, right? sometimes when you spin your tires or come into a driveway at low speeds and a funny angle, it will trip it.
    The light on my '97 used to come on and I would push the clutch in, turn it off and start it again and it would go out???
    The ABS light will come on if your fluid is low, too. Were you parked on a hill, so the fluid may have gone under the sensor when you tured it back on?
    It will probably be off the next time you start it up. Don't worry about it.
    Ligonier, PA
    6,365
    yes it has the traction control, and the funny thing is that usually when you start the car the traction control is on, and this time it was off, and wouldnt turn on at all.
    1991 BMW 325iX
    1978 Ford F150
  1. ABS Inop Light
    By bics56 in forum Other Makes / Models
    Last Post: 02-02-2013, 08:55 PM
  2. ABS light
    By Stangman in forum General Tech
    Last Post: 06-20-2008, 03:00 PM
  3. abs sensor
    By JtStyle in forum General Tech
    Last Post: 09-15-2007, 11:46 PM
  4. How can I tell if I have rear ABS
    Last Post: 02-13-2007, 08:54 PM
