Results 1 to 19 of 19
Thread: 5.0 Problem
    Selinsgrove, PA
    526
    5.0 Problem
    Ok, well just resently this has started, it does this no matter what, if the car is warm, or cold. It will run great, if i push the gas like half throttle it takes off fine and has plenty of power, but it seems when i put it all the way to the floor or wot that it hesitates and doesnt wanna go, climbs rpms really slow, and goes nowhere, but like i said at half throttle its got plenty of power..
    checked codes and the only ones its throwing are 94 & 44 which i was told is most likely because i have no smog pump and it shouldnt hurt anything, i was getting a code 34, but i reset the computer and now im not getting that anymore...
    it seems like its losing spark at wot or not getting enough fuel or something of that nature... so i was kinda leaning toward plug wires, because my plugs look fine... but who knows..
    Any help would be greatly appreciated!!!
    Fox/n.
    Selinsgrove, PA
    526
    also i just read that, if the fuel pump is going bad, that it will go to a certain rpm and not be able to go any higher because it cant pump anymore fuel, well mine doesnt do that it keeps climbing the rpms, just really slow and hesitates.. so im thinking its spark..
    also i noticed a little bit ago that 2-3 of my plug wires have white spots on them from what seems to be them resting on the headers ><... could this have made them bad and does it sound like a spark problem now??
    Fox/n.
    Ligonier, PA
    6,365
    i would take a guess: Fuel
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Put a fuel pressure test gauge on it and see what the pressure is doing. Might also be clogged converters. Just a few things to check.
    Selinsgrove, PA
    526
    Quote Originally Posted by SK@StreetLethal View Post
    >< 2 new convertors were put on like 1-2 months ago...
    Fox/n.
    May 2008
    Pittsburgh
    229
    how old is ur fuel filter cause if it is clogging up it will make the pump have to work harder under WOT
    Selinsgrove, PA
    526
    2 weeks old...
    maybe i put it in backwards? (pretty sure i didnt)
    but would that cause this?
    Fox/n.
    It may be a combination of both, if you are saying that a couple of your plug wires are burnt.. If you have a few spare laying around i would say replace the ones that are burnt so that will narrow down your search even more... My old 95 did that, once i put new plug wires on it ran fine afterwards....
    Then if does not clear anything up then concentrate on the fuel.. Def see what kind of pressure your running.
    Polar Vortex
    6,031
    does it fall on it's face more at low rpm's? If so my vote is spark problem.
    Selinsgrove, PA
    526
    if im driving around a low rpms or even half throttle it runs fine, but if i let of the gas.. it REALLY falls on its face, like it should just slow down, but in like 1-2 it just falls...
    Fox/n.
    Selinsgrove, PA
    526
    well i just took my like 1 month old coil off, and put my old one back on.. and now it pulls very hard through every gear, and seems to be fine now... wtf??
    lol
    Fox/n.
    Castle Shannon
    1,276
    what kinda coil was that ?? maybe could've just been a connection you fixed while changing them up? i'd still do something about those burnt plug wires tho... ;)
    out in the woods
    4,948
    sell it..... you seem to be having alot of trouble with it..
    .02
    or trade me!
    Chandler, AZ
    1,532
    .02
    X50000
    Ligonier, PA
    6,365
    .02
    x28383...did i not suggest that way back when the problems started? LOL.
    1991 BMW 325iX
    1978 Ford F150
    Selinsgrove, PA
    526
    y'all give up 2 easy, bought it as a project car, and it still is.. gotta get all the kinks worked out..
    Fox/n.
    May 2008
    Pittsburgh
    229
    it could have possibly been a loose ground on the coil if u dont have a good ground that would effect performance also diff. change the burnt wires i had one on my 92 hatchback that was burnt and it was grounding itself out on the header made it run like shit just a thought carry on
    Selinsgrove, PA
    526
    Yeah later when i get home from school, ill post the pics of the burnt plug wire i took, its a white mark, and its cracked in the middle.. looks like it would possibly be grounding itself out on the header as you suggested.
    Thanks,
    Fox/n.
  1. c4 problem
    By badstanglx in forum General Tech
    Last Post: 05-19-2012, 11:35 PM
  2. Little problem
    By 383taman in forum Pictures & Videos
    Last Post: 08-20-2009, 12:22 AM
  3. Problem with 91 gt
    By jclose11 in forum The Bar
    Last Post: 07-23-2008, 09:29 AM
  4. Another problem
    By Balaska347 in forum General Tech
    Last Post: 09-02-2007, 09:35 PM
  5. HP problem
    By Carbed89Lx in forum General Tech
    Last Post: 05-16-2007, 11:30 PM
