Results 1 to 10 of 10
Thread: TFS Upgraded TRACK HEAT valve springs,retainers,locks
    3,499
    These springs have been used to idle engine, run on a dyno 4 times and then pulled off because of cam change.
    * 1.460" o.d. double spring with damper
    * 125 lbs. @ 1.780" installed height
    * 376 lbs. @ 1.180" open
    * 420 lbs. per inch rate
    * .600" maximum valve lift
    * Valve Spring Retainers 10 degree x 1.50" o.d. chromoly steel
    * 10 degree locks
    New these are 194.95
    $100.00
    3,499
    t.t.t.
    3,499
    ttt.
    3,499
    ttt.
    3,499
    ttt.
    3,499
    bump
  1. TFS Street Heat / Track Heat 3/8" Spacer
    Last Post: 12-02-2013, 06:46 PM
  2. N.I.B. Trick Flow Track Heat Upper Plenum *ONLY*
    Last Post: 08-27-2013, 02:24 PM
  3. TFS Track Heat for sale
    By TJH64 in forum Ford Vehicles
    Last Post: 11-17-2011, 01:13 PM
  4. Comp valve spring retainers/bosch bypasses
    By Jivepepper in forum Ford Vehicles
    Last Post: 09-05-2008, 05:42 AM
  5. Replies: 3
    Last Post: 12-05-2007, 03:08 PM
