Results 1 to 6 of 6
Thread: opinions on setup,I bought car this way
    Junior Member dieselcrank's Avatar
    Southern WV
    13
    and what should I do to help performance
    bored 302 9500 miles.
    GT40 crate spec engine
    B303 cam
    comp roller tip rockers
    GT40X alum heads-no port work
    GT 40 upper and lower intake, tubular style,not ported
    BBK 65MM TP and MAF
    fender well cold air intake
    BBK equal shorties
    19 pound injectors
    bbk 110 pump,have 225 pump too
    2 1/2 Mac cat back,w/cats and 3" exhaust pipes
    GForce trans
    3.73
    alum. driveshaft
    KC clutch
    smog pump elem. bracket/pulley
    Motorsport wires
    adding -
    MSD 6AL
    off road pipe
    underdrive pulleys
    electric fan or fans
    battery to trunk
    MSD coil or Crane coil that I have too
    thinking about full roller rockers
    stock fuel rails, has adjustable regulator too, stock fuel lines. I dont want to port anything at this time.
    What about headers,full lenth? I've always run them in past.
    car has and will keep AC
    not sure if computer has been tuned, never been on dyno. idel surges alot for first 20 seconds.
    I'm thinking cats/removal and injectors should be next or first
    I may do a MSD distributor, the one in motor is stock and could be tired.
    This a street car, maybe to drag strip couple times a year. Also has coil over fronts, nothing to rear suspension yet.
    Thanks in advance
    owner I bought car from states 9500 miles on engine and trans, the G=Force trans has a "going into second gear" issues, up shifting and down under harder than normal power.
    port the heads, bigger cam, bigger t-body, #30 injectors, long tube headers (1.3/4"), maybe a shot of NOS...
    State College, PA
    3,552
    cam change and longtubes for sure
    2013 Mustang GT
    1999 Contour SVT
    Southern WV
    13
    like to
    stay out of the engine for this summer.
    Big questions are about injector size, 65mm TB and MAF.
    Pulleys and electric fan and alternator upgrade for sure. Removing the cats for sure.
    Whas best route on tunning the car? What if dyno not in area, will the facotry computer do enough on it's own.
    Thanks
    fairmont,WV
    1,352
    what part or WV are you in?
    XXX RWHP
    XXX RWTQ
    Southern WV
    13
    Hinton
  1. Bought a new car
    Last Post: 01-24-2011, 11:43 PM
  2. Bought A Car From Someone On Here
    By blackgt87 in forum Welcome New Members
    Last Post: 11-07-2010, 10:35 PM
  3. Who bought my car????
    By BRUNO86 in forum General Tech
    Last Post: 06-24-2010, 07:22 PM
  4. What was your first car you bought with your own cash?
    By Chargin2004GT in forum The Bar
    Last Post: 08-10-2009, 06:39 PM
  5. opinions on car
    By 89stang in forum The Bar
    Last Post: 11-16-2006, 07:38 AM
