Results 1 to 7 of 7
Thread: Need help ASAP... how do I recharge my A/C?
    Senior Member Killercanary's Avatar
    Altoona, PA
    2,338
    My A/C has been discharged since 2001 and since its going to be 90* at Carlisle this weekend I want to try to charge my AC today. What all is needed, and is there a way that I can check for leaks before I add the refrigerant? I usually search these things but I don't have the time today and really want to try and get it working. Any help is appreciated!
    -Paul
    1995 GT 'vert
    Best times on old 302 combo:
    12.03 at 112.5mph NA
    Best time with 9:1 compression NA dart block 331 setup:
    11.50 at 121mph
    Dyno'd: 415rwhp/410rwtq
    2004 Z16 commemorative edition Z06
    100% stock: 11.9 at 118mph
    Senior Member blizzard's Avatar
    Mar 2008
    Castle Shannon
    1,276
    for $15 just fill it up and see how long it lasts that'll at least tell you if there's a leak :) finding one is a lttle harder unless you can hear it.
    Big Daddy gmkillr's Avatar
    At the racetrack
    4,193
    Quote Originally Posted by blizzard View Post
    Isn't there 2 different bottles your suppose to put in there? Or am I thinking of something else?
    I thought it was suppose to be sunny and 95 degrees on Friday?
    Either way I won't be there till Saturday morning along w/ some adult beverages I might add!
    Good luck with the A/C recharge.
    Corvette Z06
    Growing up.............Not everyone does it!
    Senior Member no1sirbutler's Avatar
    fairmont,WV
    1,352
    You can buy the recharge kit at your local parts store w/ directions. As far as finding leaks, the only way I know of is to add the dye that shows up neon green where ever the leak is. Youll have to go to a shop that does A/C service to get the dye installed.
    XXX RWHP
    XXX RWTQ
    But only if I let Kenne scream at ya. LOL
    Everything I have is slow 2001GTTT's Avatar
    Ligonier, PA
    6,365
    i have a recharge canister just sitting here, i know it will work on mine, but not sure on yours.....if i see you at carlisle you can just have it.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    2001 Mustang GT - gone but never forgotten. RIP.
    Nov 2007
    enon valley, pa
    49
    Just like the guys were saying above, its hard to find the leaks without a dye capsul. I would just go to the parts store and buy the kit for 134A and fill it up. Once you have it charged, go around all the lines and listen for leaks. Also look for oil on the lines this is usually a sign that it has started to leak. After that mix some soap and water in a squirt bottle and spray all around the lines and look for bubbles. Good luck
    I have done so much, with so little, for so long, that now i can do anything with almost nothing at all.
    whatever it takes stangfever's Avatar
    i b where im at
    674
    napa auto parts sell a kit inside the kit is 2 cans and a line to hook cans up to your ac shreader valve . one of the cAns you put in first is a sealer can it has the green dye in it so if there is a leak its pretty easy to find the other is straight r134 . i think youll have to buy an extra can if your ac is completely empty .. very easy to do . make sure your ac is r 134 or you might have to purchasc a new shreader valve .. .. ive done this to several cars its very easy . hope this helps paul .
    TODAY IS THE DAY I MAKE A DIFFERENCE !!!!!
  1. need help asap
    By 95V6 in forum SN95-New Edge
    Last Post: 11-21-2012, 08:59 AM
  2. Need help asap
    By wickedsnake03 in forum SN95-New Edge
    Last Post: 06-23-2010, 10:34 PM
  3. Need Wheels ASAP
    By 393rag in forum Ford Parts
    Last Post: 07-17-2008, 03:02 PM
  4. Need Intercooler Asap!!!!!
    By dappie99 in forum General Tech
    Last Post: 06-30-2008, 07:17 PM
  5. Asap
    By Balaska347 in forum The Bar
    Last Post: 04-15-2007, 09:37 PM
