Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Compression Test
  1. #21
    Just a side note: I know you said to disable the fuel pump relay, so no gas is being squirted, but this article makes no mention about doing that step. This is why I was having some much difficulty trying to understand the proper procedure, with so many "different" ways that people had said how to perform a compression test.
    Its up to you. Unburned gas in your cylinders or no gas. Pick one. As for the article...um the car has carbs. No fuel will be injected unless you hit the gas. Just put the gauge in the spark plug hole and crank motor.....that is it.
    Gas in cylinder = Don’t take 1 minute and disconnect fuel pump
    No gas in cylinder = Take 1 minute disconnect fuel pump
    That is the only difference!
  2. #22
    Is this your first time working on a car? Its pretty much a straight forward task. The people on this forum have it nailed down where it needs to be. That guy you qouted, well, he needs slapped. Unless you are starting the engine, you dont need fuel. You dont start an engine during this procedure. Just pull the coil, pump relay, insert the compression tester into the plug hole and go. Then if you feel so inclined, do a "wet" test. This is when you do everything over again but with a few squirts of oil in each cylinder. Very simple, dont be scared.
  1. Compression
    By Hawkeye in forum General Tech
    Last Post: 01-19-2009, 04:51 PM
  2. New best for my 9:1 compression NA 331...
    By Killercanary in forum Drag Racing
    Last Post: 11-24-2008, 11:29 PM
  3. Compression test results. Please advise.
    Last Post: 07-15-2008, 12:55 PM
  4. Compression vs overbore
    By Silverhatch in forum Fox-SN95
    Last Post: 03-02-2008, 11:32 PM
  5. sc w/high compression is it possible?
    By PunisherStang in forum SN95-New Edge
    Last Post: 07-07-2007, 04:28 PM
